My G-maxx67-project
getfrey-80
My G-maxx67-project - 11.19.2009, 04:50 PM
It's my project G-maxx.
And so:
G2-chassis
Fastlane hybrid bulkheads and skid
Shocks OFNA
Tires and weells OFNA
RPM axles and arms
Body JCONCEPT
Small protection
JoFreak
JoFreak's Avatar
11.19.2009, 04:55 PM
Nice build, which motor and ESC are you planning to use?
Which diffs are those? HB lightning?
getfrey-80
11.19.2009, 05:11 PM
Thanks. Motor NEU 1515 1y. ESC Mamba monster.
Yes, Diffs Hot Bodies
Differential Ratio: 4.3
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 2.45 : 1
Total Ratio: 18.17727 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 0.98:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 45.16 mph (72.55 km/h)
Effective KV Value: 2200
Kcaz25
Kcaz25's Avatar
11.19.2009, 05:26 PM
Subscribed. Cool truck! I see you are using Revo upper a-arms, is that because RPM Maxx upper
a-arms didn't clear the shocks when using the nonGmaxx lower arms(truetrack in this case) with GorillaMaxx suspension extenders and towers?
getfrey-80
11.19.2009, 06:44 PM
1) RPM maxx upper arm weight 36 gram, revo upper arm weight 16, total revo minus 20 gr., 4=80gr. It's good.
2) I wish to make similar, but in plastic
Rivermaxx
11.19.2009, 07:58 PM
I was thinking of cutting the outside hoops off the rpm arms to lighten them up. But not sure how it will affect the strength and stability. Nice to see another g-maxx build.
maxxbear
11.21.2009, 03:36 PM
rivermaxx,what cvd boots are you using on your outdrive cvds,meant to ask you last sunday at the races,need to get some.
Rivermaxx
11.21.2009, 06:03 PM
Hot bodies boots are a better longer lasting boot. The ones on my truck are not very good.
Kcaz25
Kcaz25's Avatar
11.21.2009, 06:06 PM
So yes they clear but you use revo uppers because they are lighter?
11.21.2009, 08:41 PM
Could be, or it could be because that way, it looks more like the G3.3 suspension... only in plastic not aluminium...
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
11.24.2009, 12:50 AM
DAMMIT!!!!! you found out why I did it on my build
rccna.com
Kcaz25
Kcaz25's Avatar
11.24.2009, 10:42 AM
CHECK THIS OUT
11.24.2009, 11:47 AM
Mmm, orange...
Integy sell something similar too, as do a few other obscure places (FastTrax?)- I believe he wants plastic specifically though as its less likely to bend and get damaged compared to the beautiful metal arms..
11.24.2009, 08:42 PM
Interesting but I'm not sure I'd trust anything made by hammad ghuman...
Kcaz25
Kcaz25's Avatar
11.24.2009, 08:53 PM
Sounds middle eastern, but why not? I've never heard of them except for the fact that I've seen them there on Stormer for years.
