anyone know where to get these? I ordered one from dan @ kershaw but its going to be awhile he is waiting on the gears to come in. I'd like if someone else would make them also. (hint hint mike) If anyone knows where else lmk please.
phil
yeah it would be if I could find one that could fit with a decent ratio. smallest spur I've found is 56t and that a good bit bigger than the stock 72t 48p ,so that would mean I'd have to run a really small pinion. not what I'm looking for.
phil
Then run a 23 tooth pinion that gives you a 2.435:1 where the the 72/30 gives you an even 2.4:1.
Jeff
That would be great if it would fit. I suppose you mean a 32p. problem is they are too big to get any decent ratio. There just isn't enough adjustment.
Dan @ Keshaw Designs and SDP-Si.com are the only places I know of that sell them. I had a 21 or 22 tooth brass pinion that was 5mm bore but the grub screw rounded out and I had to cut the gear off. If I still have the gear you can have it and use some loctite 604 to stick it to your shaft.
