Brake Setting when using mechanical brakes?
BushyAR15
Brake Setting when using mechanical brakes? - 03.09.2010, 10:56 PM
I'm running a Mamba Max in my Ve8. I'm planning on using the mechanical brakes.
I was wondering what to set the ESC Brakes to so that they don't come on at all?
Seems the lowest number I can enter for "brakes" is 10%. Will that be sufficient so the motor doesn't do any braking? If not, what setting should I use and set?
TIA!
teknorc
03.09.2010, 11:02 PM
Set to Forward/Brake only
Set brakes to Custom, then 0%
Set drag brake to 0%
The actual brake servo movement will be done with mixing on your transmitter or with the use of a Y harness.
Tekno RC - Performance Parts
Thomas Porfert
Thomas Porfert's Avatar
03.10.2010, 01:13 PM
+1 for TeknoRC. If you decide to use the Y-Harness on the throttle channel, just make sure your linkages are adjusted so the brake does not engage when applying throttle.
Thomas Porfert
Castle Tech Support
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.13.2010, 09:48 PM
If you do mixing on your transmitter rather than a Y-harness, you can further reduce the chance for brake by turning the brake EPA down to 0% for the brake side after you program the endpoints on your ESC.
