IN need of a lipo charger
kevinlambchops
IN need of a lipo charger - 04.03.2010, 09:51 PM
i need a lipo charger. i am new to lipos and need to know which kind to get. needs to be cheap but get the job done. or if anyone is selling theirs for a cheap price. i will consider buying it.
04.03.2010, 10:00 PM
Cheap, gets the job done: http://www.hobbypartz.com/thac6smbachw.html
Will do upto 6s lipo, 5amp charge rate, built in balancer, lots of great reviews, good customer support from Hobbypartz too. Limited to 50watts so if you charge larger than 3s packs it will take anything upto about 3 hours ( 6s 5000mah for example ), but for typcial 2-3s lipos you're looking at about 1-1.5 hours tops.
Cheaper options are available, but they either need a seperate powersupply, or lack features & adjustability.
kevinlambchops
04.04.2010, 01:32 AM
do you have this charger? or know anyone that does? how has it worked? is it reliable? and btw thanks. i got one as a gift off of ebay and its been having problems.
kevinlambchops
04.04.2010, 01:39 AM
DanteX
04.04.2010, 03:51 AM
Hi there!
A friend of mine owns this charger:
http://hobbyking.com/hobbyking/store...w/_accessories
But you need an external power supply, like this one:
http://hobbyking.com/hobbyking/store...A_Power_Supply
He likes the charger very much, and it working properly.
It can charge almost every kind of batteries.
Regards, DanteX
kevinlambchops
04.04.2010, 04:27 PM
Originally Posted by DanteX View Post
Hi there!
Regards, DanteX
kay thanks. i am having problems with hobbyking right now becuase they take so long to ship their items. but i am hoping that this charger will be faster.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.04.2010, 05:32 PM
Not the cheapest but a Hyperion EOS0606i ac/dc is a great starter charger. Not the most powerful but it will do any kind of battery and it doesn't need a separate power supply, easy to use, and full of options
kevinlambchops
04.04.2010, 06:54 PM
thank you, i will take a look at that one.
simplechamp
simplechamp's Avatar
04.04.2010, 07:26 PM
iCharger 106B+ is what I use. Good balance between price and performance. Doesn't have all the bells and whistles of a Hyperion, but the price tag reflects that, and it can still do just about anything you'd want; charge data graphing and logging, updatable firmware, super accurate balancer. A-main sells this under their Pro-Tek line. Definitely worth a look.
04.04.2010, 09:35 PM
The Thunder ac6 is what alot of guys over on beatyourtruck have been using- a few have reported issues, mainly cold solder joints between the built in powersupply & the charger cicuit itself ( same issue with the skycharger ).
If Hobbyking is out of the question, and you want a quicker charger than all the 50watt limited ones, then have a general google around and read reviews- a ~150watt charger and suitable power supply would give quick charge times; I like the iCharger line up, been reading great stuff about them ( top name brand like Hyperion ).
Erevocanuck
04.05.2010, 04:35 PM
I plan to buy a Icharger 208B soon.It has optional balancing board that you can connect multiple batteries.Down side for me is that my power supply is 13 volts 20 amps(260 watt) and the 208B is 350 watt charger.
