Go Back   RC-Monster Forums > Support Forums > Team Tekin
Truggy combos?
Klausen
Brushless G-maxx
Klausen's Avatar
Truggy combos? - 04.04.2010, 11:16 AM
I have an MBX6-T with the RCM brushless conversion, and have started out with the RX8/2000 kv. combo on 5s lipo with a 20t pinion.
This showed out to be a way too fast setup, so I switched to 16t pinion.
But what are you guys running, I am hinking KV, how many lipocells an wht size pinion. I want to make it durable at a medium size track.
You can see the truggy here:
http://www.rcgalleri.dk/html/gal_vis...397&ipc=109536
wallot
wallot's Avatar
04.04.2010, 11:19 AM
5S - 1700kv 46/16 gearing
for 2000kv on 5S go for 13t pinion
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
 Send a message via ICQ to wallot
Klausen
Brushless G-maxx
Klausen's Avatar
04.04.2010, 01:10 PM
Thanks a lot.
Ellwood BL
04.04.2010, 08:13 PM
What kind of temps are you guys running? I have a 8T 2.0 using the Tekin RX8 1700 combo and I am running 16/45. I am getting around 175 degrees on the motor. I have tried a 17 tooth also and it was about the same. This is on a large track after 10-15 minutes. I think this is too hot and might have to back to my Mamba Monster 2200 combo since it was way faster and cooler. Any advice would be appreciated.
Klausen
Brushless G-maxx
Klausen's Avatar
04.05.2010, 12:22 AM
Havenīt actually measured the temps, just realised the setup would be crazy for the track.
But I run the MMM on my Savage, and it runs way hotter than the Tekin combo, so I donīt think heat would be an issue.
itbvolks
04.06.2010, 09:17 AM
I'm actually setup to run the same setup as Ellwood. 1700kv truggy with 16/46 gearing on 5S 4200mah Hyperions. Haven't run it yet but should be about right. Might drop to a 15T pinion depending.
Should be in the ball park.
George16
Supermaxx
George16's Avatar
04.06.2010, 09:21 AM
I'm running a RX8/2000Kv T8 motor on my ST RR with 46/15 gearing.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
itbvolks
04.06.2010, 09:30 AM
George, how are you finding the power of the 2000kv setup? I think I read your running 5S with this setup?
Trying to round out a solid race setup that will be efficient without overpowering the truck. Hoping the 1700kv setup on 5S will be enough.
I do find the sensored option very nice for a race setup from a smoothness on part throttle or under braking.
nuz69
nuz69's Avatar
04.06.2010, 10:01 AM
Theoritically, a CC/neu 2200kV should be a little cooler than the Tekin 2000kV because it can handle theoritically more power. But the 16/45 gearing is too high with 5S 2000kV... you should try 13/45 maybe. The advantage of tekin truggy motor compared to standard CC/neu 2200kV are their low kV with high voltage.
George16
Supermaxx
George16's Avatar
04.06.2010, 05:34 PM
Itbvolks, I only ran it twie for speed passes and so far I like it. I had to change the cd oil to 20 and increase punch control because it will wheelie the truggy or even flip it if I blip the throttle. I'm hoping to run it on the track this weekend.
Nuz, I wish I can use 45/13 as my setup. The spur and pinion won't even mesh with each other using the RCM kyosho mount.
Revo with OS .18TZ
nuz69
nuz69's Avatar
04.06.2010, 06:08 PM
Then maybe change the spur, what vehicle do you have ? Kyosho ST ? There is some 50 or 52 T spur .
Its better to have a big spur because you can use a big pinion for same ratio. And big pinion give mechanical energy to the spur with less loses than small pinions, the noise is also well reduced (motor temp too !!!!!) ;) and if the shimming is correct, the pinion will last a human life ^^
George16
Supermaxx
George16's Avatar
04.06.2010, 10:47 PM
I like the 46/15 gearing so I don't plan in installing a bigger spur. I have Kyosho's metal and plastic spurs ranging from 44-52T .
Revo with OS .18TZ
itbvolks
04.08.2010, 01:32 PM
George,
So with the 2000kv setup on 5s, you have enough power to flip the truck running 15/46? How's the temps been? I still think my tekin 1700kv setup on 5s should have enough power/torque to handle a ~9.5lb truck without too much issue.
Really cool conversion though! Truck looks great!
George16
Supermaxx
George16's Avatar
04.08.2010, 04:26 PM
Originally Posted by itbvolks View Post
George,
Yes, but I think that ability to flip and ride wheelies are more due to the 30K cd oil I originally have in there plus running on asphalt. I didn't even bother to check the temp using my temp gun because it was really cool to the touch. I'll try to run it on the track this weekend and do a full test and see how the Tekin system runs with my current setup.
Btw, it's a Kyosho ST RR.
Revo with OS .18TZ
Ellwood BL
04.08.2010, 10:27 PM
Itbvolks, I have the 1700 combo on 5S using 16/45. I ran pack after pack today at the track and never went above 145. The track temp was about 70. My heat issues were due to a bad solder joint and possibly a rear diff needing reshimmed.
