Front bearing Unglued itself on 2200kV motor
nuz69
nuz69's Avatar
Front bearing Unglued itself on 2200kV motor - 04.21.2010, 05:20 AM
Hello,
I encounter a small issue with my Castle motor.
Since some times, I stated some moves in my front bearing and rotor, I could move it a little.
First I tought it was my front bearing which was used prematuraly, but in fact I realize that the bearing was unglued off the bell as I can push it a little back when I push the rotor in the motor (0,5mm).
I opened the motor, dust it off and glued it myself. By the way the bearing was still in good shape, happy to state it !
Once the motor closed, no more moves in the rotor and bearing
So if you have this king of moves issues, check that the bearing is always glued in the bell by pushing the rotor in the motor.
