MMM switch pulled off at the board
pinkpanda3310
pinkpanda3310's Avatar
MMM switch pulled off at the board - 04.24.2010, 11:07 PM
I mounted the esc in a new position so I could solder the connectors directly to the motor wires. The wires put pressure on the case pullling it upward and since I only had double sided tape holding the esc it eventually split the case open.
Being a highly intelligent individual I just closed it back up and kept going ( I didn't have all my gear to remount it). So of course it happened a couple of times before it pulled the switch wires from the board.
It seems pretty straight foward to fix it but it will void the warranty if I do it. Otherwise I have to wait roughly a month if I send it to castle.
I know I should have a spare for occassions like this but I was holding out for the ICE monster. So what's your opinion wait a month or void the waranty?
