Motor & Battery Combo for New Track
Tazz
Custom
Motor & Battery Combo for New Track - 03.28.2006, 01:52 PM
I just found out that there is a new off road track being put in (open in 4-6 weeks) about 20 min. from my house!! I talked to the guy designing the track and it will be 100 ft. x 200 ft. (one 200 ft. straight)with some technical areas but over all a fast track. Qualifying races will be 5-8 min. and mains could be up to 30 min. if I have to run with the nitros (and I probably will). I am looking for a motor and batteries (lipos) that will let me stay with the nitos but be as light as possible and still do a 30 min. main. I have a 1950/7 and 8000mah lipos coming but I would like to find a lighter combo if possible. What would be good tires and also what gearing?
UE
8 Spyder Diff. Gear Sets
6mm Axle Steel CVD’s
Titanium Center Driveshafts
Racer X Pro Suspension Kit with Setback Arms
Racer X Supershock Kit
Titanium Pillowballs
G-Maxx
Alum. Chassis
Chassis Ext.
Single Speed Conversion
Steel Idler
FLM Hybrid Bulks
RPM Monster Clawz StableMaxx Wheels
Robison Racing Slipper Clutch (will switch to Strobe slipper when they are in stock)
coolhandcountry
coolhandcountry's Avatar
03.28.2006, 03:59 PM
you could get some samller mah batts for the qualifing rounds. I think you should make the 30 mins and be a fast contender as well with that set up. How many cells on the lipo are you getting.
Peace!
Country
Help support the
Rc-Monster
Buy here
Tazz
Custom
03.28.2006, 06:32 PM
Sorry, I forgot to put that in. They are 2 3s packs in series.
squeeforever
squeeforever's Avatar
03.28.2006, 06:46 PM
well, i think 40 series crime fighters with 23mm wheels is your best, lightest tire for a variety of terrains.
coolhandcountry
03.28.2006, 08:27 PM
With the tires squee says i would gear about 16 51. I think that would get you in a good speed and run time with out running hot. You may want to try it first. I run the 1950 8t on mine. I would run it at 18 or 20 so with the lower turn i figure a couple down.
Peace!
Country
Help support the
Rc-Monster
Buy here
