suspension question
furryninjas
suspension question - 03.31.2006, 08:48 PM
i just got a T-MAXX from a friend, it has been setting in his garage for about 2 years, so i took it off his hands..... its got a full INTEGY suspension set-up on it, shock towers, etc. but the front right a-arms dont have as much down travel as the left side does, its off by about 1/16 - 1/8 in. Now i know this doesn't seem like much, but it seems to make it turn badly in one direction.... what can i do to fix this problem? any ideas of why its like this, both sides seem identical.....
squeeforever
squeeforever's Avatar
03.31.2006, 10:50 PM
i would check to see if the shocks are mount in the same position on both sides.
Sneeck
RC-Monster Custom
Sneeck's Avatar
04.01.2006, 01:53 AM
Check if there aren't any bend arm's/ hinge pin's, take the shock's off and you should be able to move the whole suspension freely.
Serum
Serum's Avatar
04.01.2006, 02:08 AM
Welcome to the forum!
I doubt if this is the reason for the truck steering better into one direction than the other. I would check the possition of the knuckles in one and the other corner. Perhaps the turnbuckles are not equal in length.
For the difference in height;
You can also check the position of the piston in the rodends. (one side can be turned in deeper)
coolhandcountry
coolhandcountry's Avatar
04.01.2006, 07:39 AM
The way the drag link is hooked up makes a difference to how it steers to. The draglink I am referring to is between the servo and center linkage.
Peace!
Country
Help support the
Rc-Monster
Buy here
HotnCold
HotnCold's Avatar
04.01.2006, 08:03 AM
Also - take off servo horn and make sure you have enough travel - both ways - and make sure your servo is not limiting your steering - If the servo is off center - that would also keep the steering inadequate....... Report back and let us know if you found the problem. And Welcome to the forums.....
Hows that "Hope and Change" working out for Ya???
furryninjas
04.02.2006, 03:19 AM
well, i figured out the problem, i did have to re-center the servo, but the problem for the ofset height what that one of the shocks had a different type of lower plastic mount that bolts to the a-arm....... fixed it, now their all even, used the little pieces off my rusty shocks......, thanks.
Serum
Serum's Avatar
04.02.2006, 03:26 AM
In these situations, patience and a close look will be your helping hand..
Good to hear it's solved.
