will 100Amp's be enough ?
speedy
will 100Amp's be enough ? - 07.01.2010, 01:38 PM
Hi !
Would a 100A 12s turnigy esc be enough in a mcd 1/5 scale 4wd mt ? geared for 35-40mph on 12s ?
scarletboa
scarletboa's Avatar
07.01.2010, 02:13 PM
sounds fine to me. just remember that you will still need mechanical brakes.
worst case scenario, you might have to add a fan to the esc if you want to gear higher. i have seen this esc used before in 1/5 without any problems.
brian015
brian015's Avatar
07.02.2010, 07:19 AM
100A x 12 x 3.7V = 4440Watts
This should be enough to move it around. What motor are you going to use?
speedy
07.02.2010, 11:33 AM
I thik it will be an turnigy 170kv outrunner in 80cc size :)
brian015
brian015's Avatar
07.02.2010, 12:16 PM
This one?
TR 80-85-B 170Kv Brushless Outrunner
speedy
07.02.2010, 01:02 PM
yes :)
