SERVO Help - Custom Build
kladal
SERVO Help - Custom Build - 07.26.2010, 10:01 PM
Hello,
I have a custom build that will only barely resemble the truck you see in the pictures below by the time it's complete.
Here are the specs:
-Motor = 2217 2y 640kv CC/Neu
-ESC = Megapower 120A
-Battery = 10s (two 5s)
-BEC = Castle Creations BEC Pro at stock 5.5V
-Tires = IMEX Swamp Kong 8.5"
-Weight = estimated 22-24 pounds
I will be installing TWO steering servos for four wheel steering. I've been advised that I need a high-torque servo.
1. Any recommendations on how much torque I should have? (Thus far I've been considering the Futaba BLS352 OR SAVOX SC-1256TG).
2. Which between these two uses less power?
3. Does anyone recommend any other servo?
4. I've been told two servos be linked via a y-hardness. How will they each attain sufficient power??
5. How do I connect these so they each do the opposite?
6. Does anyone see any problems with this steering system?
Thank you for your input!
(When I asked a servo question in my other thread, no one responded).
