Integy "Universal" setup station??
georgec
georgec's Avatar
Integy "Universal" setup station?? - 08.30.2010, 07:30 PM
Bought one these a few months back and used it on my 8th scale buggy with no problems and as fate would have it our local 8th scale track closed so I sold all my off road stuff and bought a TC5X. It was then that the problems started with the not so universal setup station. The setup station came with several axle adapters but none that would fit a TC so I had to purchase a set that would..$20.00 bucks! I should have known the next problem was coming because as I said earlier I had already used the setup station on my 8th buggy. It comes with two connecting bars of different length for the toe scale and the one I used on my buggy was the shorter one, the longer bar would most likely work on a monster truck or 5th scale. So as you most likely have guessed the toe gauge connecting bar is way to long for my 10th scale TC5X even tough their add states that it will work with 1/8th and 1/10th scale RCV's!! I emailed Integy and not to my surprise they were of no help at all. I have came up with a solution to the problem, it will require a bit of machine work to the connecting bar for the toe scale.
My question is has anyone here used one of these on a TC or 1/10th scale buggy with any success?
GeorgeC
