Temporary RX wire fix? Yes/no?
Kcaz25
Kcaz25's Avatar
Question Temporary RX wire fix? Yes/no? - 11.03.2010, 08:21 PM
In a rare event the RX wire(s) pulled apart. Can I put the wires(3) back together without soldering for a couple of weeks until I am able to solder them? Please say yes!
Thanks
Zack
11.03.2010, 09:29 PM
of course
Kcaz25
Kcaz25's Avatar
11.03.2010, 09:35 PM
How do you suggest? Tape and loads of care?
Good news!
11.03.2010, 09:46 PM
Strip back .25" from both sides twist together and tape each - Then tape everything.
Kcaz25
Kcaz25's Avatar
11.04.2010, 06:42 PM
Thanks this did indeed do the trick!
Kcaz25
Kcaz25's Avatar
01.10.2011, 04:02 PM
Yep its still working, in fact I forgot about until I moved my RX. Its been moved right beside my MMM and now that big ugly taped black wire is in the way and too long. I was thinking maybe I could undo the tape and add the RX plug at the end of the old damaged wire piece.
So my question is this... How do I remove the wire from the plug and how do I put it back again once I have removed it?
Thanks,
Zack
01.10.2011, 04:32 PM
The ends of the wires ( inside the plug ) have tiny little metal pins crimped on, it would be pretty much impossible to uncrimp the wires and put the connectors back on again. You could shorten the wires a bit more and then retape, though your best option is to shorten and solder the wires back together, using some very narrow heatshrink tubing to do a cleaner job..
brushlessboy16
brushlessboy16's Avatar
01.10.2011, 06:04 PM
Put a Servo connector on where the wire break is, they do (as stated) crimp on and then just move the receiver.
Kcaz25
Kcaz25's Avatar
01.11.2011, 06:45 PM
Ah I see, bummer thanks Neil
Ben,
You mean buy a new open RX plug? I didn't think of that, I'm going to look and see if they sell them.
Tags
rx wire
