Originally Posted by freddy
Just run it, liquid tape is big waste and bad advice
I have runned mamba monster sevral dusin times in the snow and they are just fine, just be carefull with sea water(salt is conductive and corrosive)
Back to your problem, its prob bad connection to the reciver ore bec issue
i wish i would have know that before, i've never waterproofed my mamba max before and it worked great. i read just use electric silicone( i believe its called). i don't think that will void a warrant, from what i've read.
Originally Posted by Nard Cox
A friend recently had a MMM that blinked yellow and red. I tried his servo it on my MMM and same problem, than I tried my servo on this MMM and problem solved. Conclusion: his servo was dead / causing the problem. Try to swap the servo and check again.
Once you use liquidtape the warranty is avoided (IIRC), it's a choice you make and you will have to deal with the consequences. Besides trying to ''cheat'' on CC, which isn't fair, it's not smart (to say the least) to say so on RCM in the CC part of the forums
@ freddy, not everyone is so lucky. I've read tons of MMM's dying because of water. If you are running in water just liquidtape the thing and face the fact that the guaranty is over.
I wasn't trying to cheat castle, castle has been good to me (unlike novak), and i'm never on this forum, so i didn't realize that castle even came on here, but that is really cool that they do. i posted here because i thought i would get the most useful help. I was told by a guy at my LHS that he talked with castle and they said he could put it on, but then if something happened he could peel it off since its rubber and he could send it in without a problem and get it warranted, thats why i wanted to get it completely off. I'm actully looking for a new speed control. so in regards to castle, sorry for trying to cheat you, if you read this.
its not the servos, because it will randomly just clicks on and works fine, but it mainly seems to do this when the fan is unplugged. because i plugged the fan in and ran it for 1 minute and it completely shut off everything causing me to run into a parked car, then it just continued doing the red and yellow blinking with my traxxas receiver blinking red and green once i brought it back in. it also was doing it this morning, until i unplugged the fan,then it just clicked on fine and started working. I haven't tried running it with the fan unplugged, but i shouldn't have an over heating problem considering its 20F here. I will test the servos once i get home.
