Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
Soldering jig.
mjosparky
Sparky
mjosparky's Avatar
Soldering jig. - 01.28.2011, 08:43 PM
I hope this is the right place for this.
I just finished making some charging leads for parallel charging and used the soldering jig from Vigilante. I used Dean Connectors and this jig made it soooooo easy. It took longer to get the iron out then it did to do the work. Well worth the $20.
Sparky
http://www.vigilante-rc.com/index.html
Sharpchuter 245
Dyna Wide Glide
Cody.McP
01.29.2011, 01:58 PM
Oh wow, I've never seen this but I need to get one. Deans is a PITA to solder sometimes. I just did 4 of them a couple of days ago and this would have turned an hour of frustrating soldering into probably 10 minutes.. What a great idea. Thanks for the review!
01.29.2011, 02:46 PM
I just use a pair of vice grips to hold the connector. Then, just hold the wire and solder it on there. If you are soldering so long that the wire is too hot to hold, you are taking too long and need to practice soldering.
01.29.2011, 02:59 PM
The bench vise is your freind when soldering deans. And for 20 bucks you can get a decent one from harbor freight. However, if you are always putting on deans this jig looks very handy. I might buy one, would like some better pics of it and how it holds everything.
Cody.McP
01.30.2011, 12:33 PM
Hmm well maybe I am not soldering correctly, as I can't seem to get the solder to "melt" into the wire unless I get the wire too hot too hold.. Maybe I need different solder? Or maybe I'm just no good at it.
wallot
wallot's Avatar
01.30.2011, 01:20 PM
who cares about deans when there are much better connectors and bench vise is much better than a single purpose jig :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
 Send a message via ICQ to wallot
mjosparky
Sparky
mjosparky's Avatar
02.06.2011, 02:01 AM
You are not the only one that reads these forums. You ever think someone else might be interested? As for Dean’s not being that great, that is just your opinion and who cares about it.
Sparky
Sharpchuter 245
Dyna Wide Glide
wallot
wallot's Avatar
02.06.2011, 08:44 AM
exactly it is my opinion and those $20 can be spent on standard vise that will do much better job and not just for soldering so you dont end up with a million of single purpose stuff
Radek
*EX-10 Eurus*
Cody.McP
02.06.2011, 02:53 PM
Well I still think it's cool, I'll probably get one. Will make jobs much faster for me than a bench vise will, too.
mjosparky
Sparky
mjosparky's Avatar
02.06.2011, 04:14 PM
You will probably be better off with the vise. It will go well with your hammer. I’ll stick to "right tool for the job" theory.
Sparky
Look at it this way, a vise is just a large heat sink.
Sharpchuter 245
Dyna Wide Glide
George16
Supermaxx
George16's Avatar
02.06.2011, 06:05 PM
Sparky
Unless the vise is made of plastic instead of metal .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
mjosparky
Sparky
mjosparky's Avatar
02.06.2011, 11:01 PM
Yea, a vise made of plastic makes sense.
Sparky
Sharpchuter 245
Dyna Wide Glide
95ROLR
02.06.2011, 11:42 PM
I agree a vice is quite valuable, but I much prefer this jig...
http://thejigsup.net/
mjosparky
Sparky
mjosparky's Avatar
02.07.2011, 12:41 AM
I I looked at that one and it seemed well made and versatile. But the jig from Vigilante seemed better suited to my needs.
Sparky
Sharpchuter 245
Dyna Wide Glide
maneba
02.07.2011, 03:59 AM
I've bought it but it's useless.
The jigs subtracts heat from the connectors you are welding (not the case of the deans) and this is a bad thing. Worst 20$ spent in rc equipment.
