Looking good! nice and smooth. (except for the braking part perhaps.. :p )
Just out of curiosity;
why do you use 8 firm springs? really no need for it, you can do with 4 of them, and the coil-overs. so what's the use of having 8 of them? have you got the coil-overs?
Robinson does make a mod a pitch gears. It fits a mgt but will fit a maxx as well. They are metal though. I have not noticed a plast one out. The strobe is a better set up IMO.
That is a nice truck. Looks to run nice. I see you try to be smooth with the trigger. Hard to drive with front tires off ground.
Peace!
Country
Help support the
Rc-Monster Buy here
Nice truck, whats your shock setup on it? Hoping i'll get similar stability with mine. I have the Integy shocks with 4 firm UE springs and 4 soft UE, with heavy oil.
You need to get that Strobe on there! Its a nice price of kit. I liked the Robinson Racing slipper as well, I used one till I got a Strobe.
I am running 8 powerstrokes w/ 70 wt front and stock oil in the rear. I am using the extra Firm Spring Kit on all 8.
I am planning on bashing, so weight is not a concern. I thought I would try with 8 and run some sag in the rear (negative travel). We'll see over time as I get brave and start jumping. @ $29/pair I thought it would be a worthwhile experiment. So far so good. You also must admit it looks sweet!! :027:
