Gear ratio reduction in Ofna GTP. -
03.17.2011, 11:04 PM
I am looking to lower the Differential gear ration of my GTP and was looking to see if there are other ring and pinion sets that will fit the GTP where I can lower the gear ratio. Thanks.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
It's already taller than most 1/8th buggies at 3.14:1. What about bigger pinion, smaller spur and/or more voltage? Can't be that hard to make it go faster.
Neu has one the 1515 4100kv 1D or the .5Y 4400kv 1515 motor. Or there is the C50-6L 4080kv Hacker too. How fast do you really want to go? Or is it all about acceleration for you?
100+ on 6s and bullet fast on 4s. The parking lot races around here are limited to 4s so I need to compete with the guys running higher KVs with same voltage. I know I can gear the 2200 up without any issue but lowering the G/R at the same time would overcome the higher KV motors.
CF Losi LST2
I see. Bullet fast will need to be a 4 poler for sure. You will be surprised how fast the 2700kv 1515 motor can be on 4s. And you having the CF chassis, will be even quicker out the hole.
I think my Rustler weighs 6.5... Is that RTR minus the battery? The 36-60 is much lighter than a 1515. It might be worth doing a test drive and see how it goes. It is a 4-pole after all and should be able to throw that weight around pretty good.
