I would say though that with the BL Emaxx's 6.3" tires ( I assume you are using those ), something like 20-22/68 gearing will be fine for ~40mph topspeed- adjust gearing up or down depending on motor/esc & battery temps ( hot motor + cool esc = gear up, cool motor + hot esc = gear down, hot everything = gear down ).
Looks like a dodgy copy of the castle MMM system- even the esc case and layout looks nearly identical. I too would default all the settings, adjust your lvc for 3.2-3.4v per cell ( if possible ), then take it from there....
I found the problem :)
It was the throtle expo setting that made the motor act funny !
On this esc i can only activate the "auto detect" or nicd/nimh mode...
I have the mmm combo that came with the truck but i don'whant to use it now when it's springtime and extreamly wet outside.
I,ve waterproofed the anaconda esc.
