Sluggish acceleration
speedy
Sluggish acceleration - 04.03.2011, 11:10 AM
Hi !
My 1900kv motor acts like an nitro engine runing rich what could cause this ?
It's a new motor and i have 5000mah 40c + lipos.
Mybesc setup are: timing:low acc :high and no punchcontrol.
speedy
04.03.2011, 01:38 PM
I think it was the timeing that were set to low :) i increased it to normal and the motor got a'lot more snapier
speedy
04.04.2011, 02:54 PM
Hm the motor is still reving up very slowly ? What can cause this ? Could it be that i,m used to 2 pole motors ? Because they are snappier than 4 pole motors right ?
Dj_Sparky
04.04.2011, 03:47 PM
Reset the ESC to default..
speedy
04.04.2011, 05:48 PM
Why? The motor preformance was worse with the default settings !
Dj_Sparky
04.04.2011, 05:50 PM
That's weird. What motor and ESC do you have?
speedy
04.04.2011, 05:57 PM
http://shop.lindinger.at/product_inf...ducts_id=80585
speedy
04.04.2011, 05:58 PM
The motor is runing cool after 10-15mins of bashing the motor temp was 35celsius and the esc 15c
Does 4pole motors like high or low timeing in general ?
el tomaso
04.19.2011, 12:31 AM
I think the 4 pole motor generally likes low timing. btw is that really a 4pole motor?
Thomas G
slimthelineman
slimthelineman's Avatar
04.19.2011, 01:12 AM
Wow I must say that is the most blatent cc rip off of a mmm I have seen so far. Can't comment on getting your motor to snap harder, Since it's not a cc esc I donk know what kind of programing it has, all mine hit max rpm in about a second in my rigs. D wind four pole likes low timing and y wind four pole likes higher timing. Make sure your connections are all good.
BIG-block
04.19.2011, 10:19 AM
Bloody hell is it ever!!! The casing looks identical and I bet they even had a decent go of copying the internals. At least TORO/Trackstar tried to make it sort of look like the RX8. That is about as blatent as it gets.
josh9mille
josh9mille's Avatar
04.19.2011, 10:36 AM
wow that is pathetic! They even gave it a CC type name....the Anaconda!
thzero
04.19.2011, 11:09 AM
Anacondas are for girly men... Mambas are for real men!
