Mamba Max does not work after update
dadgummit
Mamba Max does not work after update - 06.26.2011, 12:21 AM
I just updated an older Mamba Max ESC to the newest firmware today and it no longer works.
I had to update it so I could use a castle link on my 64 bit windows 7 computer.
When you turn on the controller and turn on the transmitter both the red and yellow leds start flashing very fast. According to this page:
http://www.rc-monster.com/forum/showthread.php?t=20020
That means it is over temp which is silly because it is 72 degrees in the house and the esc is not hotter than that. It is cool to the touch.
The steering servo works but the ESC will not send any power to the motor nor does it let me calibrate it to the transmitter.
I tried downgrading the firmware to the next few lower versions with the same results.
I also turned off the low voltage cut off but this did not help either. I am using a fully charged GP 3300 stick pack and a fully charged Neu 5000 2s Lipo. both with the same results.
Does anyone have any idea what can be wrong?
*Edit
I also tried using a different radio/ receiver combo with no difference
I also tried using a different motor with no difference
Cen ME16 Sidewinder 5700
CRT.5 MM + 1509 1y
FLM Rustler MM & 7L
E-Maxx Hv maxx 6.5 + FLM E-Maxx
Stock E-Maxx for friends to bash
8ight-t 1515 1y in the works
What's Next?
