Monster x motor start fail. No power on start from stop
Dragonfueled
Nore more bump boxes and after run oil
Monster x motor start fail. No power on start from stop - 09.11.2015, 10:55 PM
Hey guys running into an issue with my monster x in my truggy. When it's sitting still and I punch the throttle it takes off like I have allot of torque control engaged. It's really slow for about 2 feet then kicks in and takes off. Other times it takes off slow and then stops while I'm still on the trigger and blinks motor start failure. I pulled a log and its pulling 75 amps from a standstill acceleration. Is that enough to kick in a motor start failure code?
Current setup
1965kv truggy motor
Et48 15/44 gearing
4s 5000mah 40c
Tried three motors same issue.
Any ideas?
If I take off and get moving first it's ok. All current limiting and punch control is disabled.
Brushless ..... I put that s... In everything.
