33.6v xlx vs 34v xlx question . Lack of ability
phildogg
phildogg's Avatar
33.6v xlx vs 34v xlx question . Lack of ability - 05.24.2017, 12:29 PM
We were told only thing was a sticker change no other difference. Myself and many other people have found this to be not true. When the esc is pushed hard it is always 10-15 mph slower than the xl2, or 34v xlx. This is not just a one time thing but many have noticed this problem. Can we please have a non limited esc?
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Pdelcast
Pdelcast's Avatar
06.02.2017, 06:00 PM
I asked my software folks about this, and got this reply (below) -- so, it seems it's just a firmware modification. Back down to 1.78, and get the fastest possible setup on the XLX.
From Robert:
First off there is only one version of the XL X here at Castle, we did make some changes to packaging but no changes were made to hardware. There are several different versions of software available for the XL X, some versions will be better for different applications, and I think that this is why the Red and Silver XL X feel different to you. Please take a look at the information below and make sure that when you compare your XL X’s you verify the settings and the firmware versions.
Facts:
The original firmware V1.72 does have some unintentional pullbacks on acceleration, I promise we are not trying to ruin all your fun, and we now have software available that corrects this issue
When you set Current Limiting to Disabled it is disabled (no lies here I even double checked the code!)
The Start Power settings is very important and I would recommend that you select the High value if you are trying to maximize acceleration
Also note that wire gauge and wire length as well as the quality of the batteries is very important when trying to maximize acceleration
Mamba XL X Firmware Versions:
V2.02 - New firmware which is optimized for racing and crawler vehicles
This version is ideal for racing because of the new drag brake system, which will allow smoother brake transitions when cornering. This version will also be best for crawlers. This version might not be ideal for drag racing, we did not intentionally change acceleration, but the systems that we added might have slowed acceleration. If you are concerned and want the absolute best acceleration I would recommend V1.78.
V1.82 - Same as V1.80 with a minor bug fix for brushed motors
V1.80 - Same as V1.78 with some minor bug fixes
These versions are essentially V1.78 but they include minor bug fixes, none of these should affect acceleration.
V1.78 - All acceleration pullback systems were removed, Also added current cutoff disable
This is most likely the fastest firmware version available for the XL X, we spent weeks pushing the XL X to its absolute limits. Our main test platform was a Losi 5T geared for 80mph on 8s, we even added 15 pounds of lead to the car to make sure that the vehicle was able to accelerate flawlessly in the most extreme setups.
V1.72 - Initial production version, includes acceleration pullbacks
Patrick del Castillo
President, Principle Engineer
phildogg
phildogg's Avatar
06.02.2017, 06:35 PM
Thanks for the reply Patrick. I have since purchased another new xlx 33.6 and this one is worlds different from my other. esc change only from old 33.6 to a new 33.6 both same setting and firmware picked up 6mph. i don't understand why but something must be wrong with the old one. maybe there is a bad batch out there? anyway thanks for the reply and insight..
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Pdelcast
Pdelcast's Avatar
06.02.2017, 06:42 PM
Hmmmmm...
Possible there's an issue with the current measurement on the slow ESC. It may think the current is higher.
Not sure. You can always send it in for a checkup.
Thanks!
Patrick
Kcaz25
Kcaz25's Avatar
06.03.2017, 10:38 AM
You are the best for your help Patrick
