What motor can replace feigao 540c 7xl ?
Wittenborn
What motor can replace feigao 540c 7xl ? - 10.06.2006, 05:15 AM
I was thinking of buying the 7xl, but then I canīt use all the 1/8 pinion gears that I have. Is there any motor that can replace the 7xl with a 1/8 shaft ??
Or comes close to ??
Regards
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
10.06.2006, 06:18 AM
You would be far better off simply purchasing some 5mm shaft pinions - a 7XL with a 1/8" shaft will probably end up snapping it, espically if you plan to use it in a fairly heavy car.
  Send a message via Yahoo to Rtsbasic
Wittenborn
10.06.2006, 08:25 AM
I just can´t find 5 mm bore pinion anywhere. They are out of stock at RC-Monster for E-maxx (unless the mod1 5 mm can be used)
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
10.06.2006, 08:31 AM
Mod-1 pinions are better than 32 pitch, however you would need a "strobe" slipper to use mod-1 spurs (1/8 buggy spurs).
I'm not sure where else you will find 32 pitch 5mm pinions, the ones I have were purchased from RC-Monster I'm fairly sure.
Wittenborn
10.06.2006, 08:42 AM
I think I have tryed everywhere - guess I just have to wait.
By the way will the Quark 80B handle the 7xl ? can it be compaired to the warrior 9920 (out of stock also :-) )
Cartwheels
10.06.2006, 09:40 AM
You'll need a Quark 125b. You may also have to add a heatsink to it to keep it cool as well.
Wittenborn
10.06.2006, 10:11 AM
What other motors can be recomended that gives the same or more power/torque as the 7xl. with the Quark 125B
(for an E-revo with 2x7 cells /2s2p 8000 mah lipo)
Serum
Serum's Avatar
10.06.2006, 10:55 AM
I have seen an XL on ebay with a a 1/8th shaft. I thought it was a 7XL..
MetalMan
MetalMan's Avatar
10.06.2006, 05:14 PM
Most likely you won't be able to find a motor that can push out more power than a 7XL without paying a lot more. But keep in mind that the batteries supply the power, so better batteries will allow the motor to be more powerful than cheaper batteries. Also, if you use more cells, then you will get an increase in power.
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
10.07.2006, 07:23 AM
I was just about to put one of my Quark 125's on ebay it was all setup (5mm plugs,deans plug heat sink and a bec) All you would have to do is plug it in and strap it down. If your interested send me an email. You would probably be better off with an 8xl if your going to use lipo or good nihm's. It will still have plenty of power run cooler and give you longer run times. I also have a few 5mm 32 pitch gears if Mike cant hook you up with one.
Never fight an ugly man..... he has nothing to loose
Wittenborn
10.07.2006, 09:50 AM
smertzog: I´m interested. Give me your emailadress and lets see what we can find out.
Mine is - wittenborn@email.dk
