Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Set backs
neweuser
neweuser's Avatar
Set backs - 10.28.2006, 03:24 PM
Anyone use the set backs with Hybrids? Mine won't fit!!!
squeeforever
squeeforever's Avatar
10.28.2006, 04:04 PM
Yea, I have heard that you will encounter slight problems like that when mixing UE/FLM parts...
neweuser
neweuser's Avatar
10.28.2006, 04:52 PM
I think I can shave the bulks a tad....should be fine....RC is Modding right!
squeeforever
10.28.2006, 05:01 PM
Yea, you should be able to file something down to fit....Either the arm or the bulk....
neweuser
neweuser's Avatar
10.28.2006, 05:36 PM
It's less than a mm, so i'll do the bulk, that way, if i ever change bulks to vbs, i can still use the arms.
HotnCold
HotnCold's Avatar
10.28.2006, 06:11 PM
thats thinking - good choice on shaving the bulks
Hows that "Hope and Change" working out for Ya???
Serum
Serum's Avatar
10.28.2006, 07:52 PM
I used mine on the FLM's. i didn't need to take off much, not a mm.
neweuser
neweuser's Avatar
10.28.2006, 08:10 PM
Yeah, it's less than that, very minimal...jsut using a file, try it, take a little more, try it, take a little more, and walla!
Thanks walter! I thought about taking material from the arm, but then there is compromising the strength as well, so i figured, plenty there on the bulk, just shave a tad and good to go.
Serum - did it work well for you?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.29.2006, 12:48 PM
glad you were able to get it on.....a few more peices and your back in business
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
Setback rear upper arm question
neweuser
neweuser's Avatar
Setback rear upper arm question - 10.29.2006, 09:20 PM
Is it normal for the upper rear arm brace to be close to the diff cup? It just seems awfully close when it comes down, and it touches the diff cup. Is this normal?
squeeforever
10.29.2006, 09:21 PM
Got a picture of exactly what your talking about?
sjcrss
sjcrss's Avatar
10.29.2006, 09:38 PM
No it's not normal....mine is a good 4mm or so from even coming close to touching the diff cup....
Bl E-REVO
Quark 125b
((2s2p)(4s)
sjcrss
sjcrss's Avatar
10.29.2006, 09:40 PM
Well after looking at mine a little bit..I think you might have your camber off on the outer knuckle....you do have those on right.....if not it will hit....and you need to use the hole on the top row..I think the second one from the end of the knuckle ( the side that faces the upper arm...)
Bl E-REVO
Quark 125b
((2s2p)(4s)
neweuser
neweuser's Avatar
10.29.2006, 10:35 PM
Cool, i got it.
Serum, did it work well with your Hybrids?
captain harlock
RC-Monster Captain
captain harlock's Avatar
10.30.2006, 02:40 AM
I'm using my setbackers with the FLM Hybrids and it work flawlessly, not befor filing off some material from the arms, though.
BTW, neweuser, do you have some pics of your truck with the RacerX suspension? I would like to see it.
ID:	1912   Click image for larger version
Nice to meet you!
