HPI BrimStone
BitHed
HPI BrimStone - 10.30.2006, 04:10 AM
...I guess this is much a good place as any...And please excuse the name...All my projects tend to get funky names :o
...A pretty basic one, nothing special...This is kind of a long term project that didnt turn out to be as 'long' as i expected...
..The GP power source is out and is being replaced with a Feigao 9L at this stage, with a Monster Max going in when it appears...
...This is it where is it is right now and I have already figured out the bits that are wrong...
...Right now the motor is flat on the deck and faces FORWARD; the center diff has been flipped...The motor plate is converted from an E-Savage...
...I need to update that and get the motor up on the rear uper deck, which is a REALLY crappy carbon right now but will be redone with either an alloy plate full of holes or I will hit up Holeshot to do me a fitted piece...
...I also want to stand the steering servo up...The front deck is the stock version cut to fit...I will cut the servo piece off and use the top deck from the throttle sevo to replace it...Hope that makes sense...
...It is spot on 4kg at the moment and i still want to fit the wing so i will strat to redo all the heavy bits once the design is set...
...Its nowhere near as technical or as blingy as many of the conversions you may have seen but it is nice and basic and a reasonably easy job :013:
ID:	1914   Click image for larger version
ID:	1915   Click image for larger version
