2.5 chassis: CVD’s for a single speed
rustnpede
RC-Monster Parking Attendant
rustnpede's Avatar
2.5 chassis: CVD’s for a single speed - 11.05.2006, 02:34 AM
So I put together my single speed and grinded away enough of the chassis for it to drop in. Now I need to link it to the diffs. What are my options? CVD’s? 3.3 Sliders? I haven’t decided on electronics, most likely an 8L.
BlackedOutREVO
11.05.2006, 04:02 AM
well grind off the humps on the chassis and then u can use two long center revo shafts witch are cheap and work very well, and for the motor i think u want a 8xl the 8l is smaller and it will heat up faster
Serum
Serum's Avatar
11.05.2006, 04:52 AM
8L is quite hot.
neweuser
neweuser's Avatar
11.06.2006, 04:33 PM
Stick with xl's
rustnpede
rustnpede's Avatar
11.14.2006, 02:12 PM
Originally Posted by E-MAXX Rock's
. . . grind off the humps on the chassis and then u can use two long center revo shafts. . .
You are refering to the center rear driveshafts right?
Any tips on how to figure out where to drill the chassis to mount the tranny.
abiye
11.14.2006, 02:21 PM
if you are going to use the slider centre shafts (which is a good idea) then its not that critical where you drill the holes as long as you can mount the tranny... the sliders alow you some flexibility as to where the tranny sits
rustnpede
rustnpede's Avatar
11.14.2006, 05:28 PM
Any tips on making a template before drilling into the chassis. I figure I only have one shot at this.
11.14.2006, 05:35 PM
When I made by first Revo this way, I just measured the distances between the varous holes...
