when you dampen the suspension, nothing gets in the way? if so your doing good, next is what holds the batterys down? just a bump or jump or steering the truck wil make the battery jump inside your body.
everything seems ok, just make something to hold the batts down.
thanks for the help, i just put it together, hope to test soon , ill let you know, if i stack the batterys it wont be as evenly weighted? but well see in a couple weeks
well what motor you using ? my feiago 8xl weights more then 1 pack , so i stack both packs toawards the rear so it evens more, thats prolly why it flips ! :P
then if you use the motor on one side then it would be a good idea to put everthing else on the other, (motor, esc, servo, reciver, ect....)
what i do to evenly balence it is to....simple put three or four fingers where i think the middle of the chassis is and pick it up, what ever tilts to a side isn't well distrubuted.
