heat sink on rusty
t-maxxracer32
t-maxxracer32's Avatar
heat sink on rusty - 01.09.2007, 09:45 AM
hey im not really sure how this would fit but would this be able to fit onto my rusty http://www.rc-monster.com/proddetail...d=RCM01&cat=20 (i have the mm 5700)
im not afraid of haveing to modify things.... just afraid of breaking them beyond repair. im looking for a nice heatsink for the mm because... well... i have a tendency of making things hott and forgetting to check the temps.. dont want it burning up!
ive been looking around for some nic batteries and i dont want to spend 200 bucks on one battery so how is this lipo? http://www.rc-monster.com/proddetail..._2S4000&cat=18 what can i expect the runtime to be? also how long does it take to charge these? how much more power will the 2s give me compared to a 7 cell ib3800
also can you buy like the housing of the mm esc? mine fell out of the truck and was dragged for a good amount of time... (i was inside playin some 360 while brother was driving my truck... :035:)
thanks guys!
**EDIT** what is the point of these ubecs http://www.rc-monster.com/proddetail.php?prod=6vubec? does it make your esc not run as hott? or is it just like another battery for all your electronics?
thanks one AGAIN!
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
01.09.2007, 09:55 AM
ubec is to bypass the esc's bec.
runs a little cooler then, the mamba max.
losi 8ight-t
xray xt8
t-maxxracer32
01.09.2007, 10:09 AM
so is it worth the 37 bucks?
jollyjumper
RC-Monster jumper
01.09.2007, 10:16 AM
i dont think so since your on 7.4 volts.
mm's bec handles that just fine.
losi 8ight-t
xray xt8
Serum
Serum's Avatar
01.09.2007, 12:33 PM
You can use the internal BEC of the MM up to 3S.
Mike.L
Mike.L's Avatar
01.09.2007, 04:52 PM
Yea the rcm heatsink sould work, I think you just need an S size heatsink.
  Send a message via MSN to Mike.L
Sylvester
Sylvester's Avatar
01.09.2007, 05:02 PM
Personally i wouldnt run the MM's bec on more than 2s/6 cells.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
t-maxxracer32
01.09.2007, 06:05 PM
ya well i plan on running 3s lipos or 3s a123 cells i still havent figured it out... too confusing!
t-maxxracer32
01.09.2007, 06:06 PM
should i send an email to mike and ask if the heat sink will fit?
Mike.L
Mike.L's Avatar
01.09.2007, 06:53 PM
i dont know why a s size sink wouldnt?
Sylvester
Sylvester's Avatar
01.09.2007, 07:02 PM
What motor are you running?
If its a 540 motor can size mikes heatsink WILL fit.
Losi 8ight e
t-maxxracer32
01.09.2007, 07:59 PM
ya its the mm 5700 so a 540 can but my main question was will it fit the rusty. also how much cooler should it run? like -20 degrees or how does that work?
Sylvester
Sylvester's Avatar
01.09.2007, 08:05 PM
Hmm than that will be a problem ; the screws on the motor holding the rear endbell and the screws in the front wont let any heatsink sit properly to actually dissapate any heat. Why do you need a heatsink anyway? If you are running to hot than your either under or over geared.
Losi 8ight e
Mike.L
Mike.L's Avatar
01.09.2007, 09:02 PM
but if your gearing is fine then yould have to ask mike for the dimensions are and see it you have that mutch clearence where you have your motor in...
Sylvester
Sylvester's Avatar
01.09.2007, 09:05 PM
Either way, Mike, a heatsink is rather useless if it isnt touching the can properlly.
Losi 8ight e
