Diff riped to shreds
ncalenda
Need for Speed
ncalenda's Avatar
Diff riped to shreds - 01.15.2007, 01:35 AM
I want to get a strong diff, which one should I get?
I use my e-maxx on the sand, so the rear gets all of the abuse.
  Send a message via AIM to ncalenda
captain harlock
RC-Monster Captain
captain harlock's Avatar
01.15.2007, 05:28 AM
You need to get yourself the FLM Hybrid bulkless and two sets of HB diffs. You find them in this store.
I assume you're using the stock diff, right?
Nice to meet you!
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
01.15.2007, 06:29 AM
is it the ring and pinion? if not=> if your in sand only, i'd try a spool first.
if its the ring and pinion you'll need 1/8th diffs.
losi 8ight-t
xray xt8
ncalenda
Need for Speed
ncalenda's Avatar
01.15.2007, 10:50 AM
When I opened up the diff, the 2 small gears were missing teeth, the pinion gear was fine.
jollyjumper
RC-Monster jumper
01.15.2007, 11:03 AM
maybe you otta try running a spool, will be far cheaper then a 1/8 diff.
losi 8ight-t
xray xt8
Procharged5.0
Procharged5.0's Avatar
01.15.2007, 11:10 AM
I'd second that opinion for use in the sand. no need for diff action there.
ncalenda
Need for Speed
ncalenda's Avatar
01.15.2007, 11:43 AM
ok, thanks.
I'm sure it would be ok to run it with the spool on dirt, grass and pavement. What would be the draw back?
GorillaMaxx360
GorillaMaxx360's Avatar
01.15.2007, 11:55 AM
where can you find spools at. and what are they
Procharged5.0
01.15.2007, 12:09 PM
Spools are harder on the axles. Since both turn at the same speed ALWAYS when you turn one wheel has to "slip" or break traction for the vehicle to turn.
It's harder on parts. On grass or dirt.....no big deal. It will be more noticeable on pavement. Also, the rear end might "wash out" or slide easier on dirt track with the spool.
@GMAXX360
A spool is essentially a solid connection between the two axles. It strengthens up and lightens up the rear axle assembly but reduces the truck handling quality somewhat. Particularly in turns.
GorillaMaxx360
01.15.2007, 12:24 PM
ok thanks
Procharged5.0
01.15.2007, 12:25 PM
BTW, Traxxas sells spools for the T/E-maxx.
