g2r revo chassis
entjoles
g2r revo chassis - 01.16.2007, 12:58 AM
this is a question to all of you that have used this chassis. should i scrap the revo chassis and trans and go for the ultimate set up? i would like to race this truck and it is probably much more durable and balanced right, any pros and cons (price) im missing?thanks for your help
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.16.2007, 01:26 AM
The Pro's are nearly endless. Better CG, little modding required, easy to work on, etc.
Cons would be less ground clearance and price...but thats about it.
I absolutely love my G2R...
MetalMan
MetalMan's Avatar
01.16.2007, 01:42 AM
I don't own a G2R, but my semi-stock chassis (non-3.3 extended chassis) works well for bashing and protecting the batteries. It is a higher CG, but a low GC isn't always best. And for me, I wouldn't be able to spend $280+ on a chassis (I've probably spent $10 on mine).
crazyjr
crazyjr's Avatar
01.16.2007, 02:27 AM
I have one and BP is right, its the hot setup for racing, But one con he didn't mention was it may be hard to mount electronics due to the laydown shocks. here's how i mounted mine, reciever on the opposite side to the steering servo, Esc on a custom plate mounted to the motor mount.
I to Love my G2R, So much so, that i want to build another
entjoles
01.16.2007, 07:51 PM
thanks for the great input, i may try the revo chassis for a while, still need to get batts and charger, i plan on running a hvmaxx 4.5 and after the sliperentual(?) comes out for the g2r ill get both
Sylvester
Sylvester's Avatar
01.16.2007, 09:30 PM
Instead of the novak id reccomend a 7xl or 8xl on a 9920 w/UBEC for way more power than the novak 4.5, it will also run cooler.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
crazyjr
crazyjr's Avatar
01.16.2007, 09:54 PM
if you're racing, the 9XL might be better
Sylvester
Sylvester's Avatar
01.16.2007, 09:57 PM
Yea, and even though it has less winds, you could always gear up to compensate.
Losi 8ight e
crazyjr
crazyjr's Avatar
01.16.2007, 10:13 PM
well, you don't need speed to win and the 9XL might be easier than the 7 or 8XL on batteries
Sylvester
Sylvester's Avatar
01.16.2007, 10:41 PM
Yea, but it might not get the speed you want.
Losi 8ight e
entjoles
01.17.2007, 01:30 AM
thanks i just took a look at the 9xl and the 9920 with the ubec its cheaper than the novak, my question is how easy is this to set up speed controler, and ill probably run 12 -14 cells till i can get lipo, also is the duratrax ice a good bang for your buck charger? looks to do all i would need. thanks for your help
crazyjr
crazyjr's Avatar
01.17.2007, 02:36 AM
They're not too bad, if you can solder good. 12 to 14 cells will give you a little faster than the titans for the given cell counts, Lipo's are the deal for high-powered setups, but if you don't know much about them, do a lot of reading beforegetting them, Knowledge is power. For gearing, try a 18 to 20/66 (32 pitch) or 16/51 Mod-1 (recomendation: Save your money and buy a strobe and go Mod-1) not even the robinson slipper can hold the power of the XL motors, it did ok on NIMH cells, but not on LIPO.
The duratrax ICE is a good charger and can charge you're LIPO's when you get there, don't forget the balancer.
MetalMan
MetalMan's Avatar
01.17.2007, 02:42 AM
The only problem with the ICE in this case is that it can only charge up to 10 cells. I have heard of people tricking the ICE into charging up to 12 cells, though (by altering the peak sensitivity).
crazyjr
crazyjr's Avatar
01.17.2007, 02:58 AM
If he's running 6 or 7 cell packs, it won't be a problem. I know he has only one charger, but if he charges all his packs before going to the races, he can repeak them before using them
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.17.2007, 03:01 AM
I dont even re-peak before I run. I just charge the packs the night before and they run fine (my GP3700's).
