G-Maxx Carbon Fiber Ground Up Build
HamMaxx
G-Maxx Carbon Fiber Ground Up Build - 03.22.2007, 10:01 PM
Well I have been reading and learning from a lot of the members of this forum so I thought I would share the results. This is a ground up build and I picked a lot of parts based on what I read in the Forum. Thanks!
However, I also picked parts just because I liked them or because it was a "easier" so don't be too critical. :026:
Here is a list of parts:
Chassis / General
Gorillamaxx G2 X-Brace Carbon Fiber Chassis
Gorillamaxx Aluminum Motor Mount
Gorillamaxx Race Skip Plates
RPM Skid Plates
RPM Black Rear Step Bumper
RPM Black Front Bumper
RPM Shock Tower and Body Mounts
RPM Bulkhead Brace
Hardcore Racing Front and Rear Bulkheads
Traxxas Bumper Mounts
HexHeads AP Screws
Traxxas Receiver Box
Axial Diablo Body
Transmission
Gorillamaxx G1 Single Speed Conversion
Traxxas Output Shaft
Traxxas Input Shaft
Traxxas Output Gear 31T
Traxas Gear Box Halves and Idler Shaft
RC Monster Hardened Steel Idler Gear
Robinson Racing Slipper Kit 70T
Robinson Racing Pinion 12T
Traxxas Slipper Tension Spring
Differentials
Integy Gear Box Collar Silver
Integy Rear Gear Box Silver (Used 2 Rears - Long Story)
Traxxas Differential Gear Set
Maximizer Diff Cup Kit with Mod Robinson Gear
Engine, Driveline and Suspension
Novak HV Brushless System 4.5
Acer Racing Ceramic Nitride Bearing Kit
RPM A-Arms Black
RPM Axle Carriers w/Bearings
Proline Steering Kit and Servo Saver
Lunsford Racing Titanium Turnbuckle 1 3/4" For Steering
Traxxas Rod Ends Short w/ Hollow Balls
Lunsford Racing Titanium Combo Kit (TB and Pins)
MIP CVD Center Drive
MIP Shiny CVD Kit
Traxxas Big Bore Shocks
Traxxas Aluminum Caps Pivot Ball
Traxxas Aluminum Pivot Balls
Traxxas Wheel Hub and Axle Pins
Axial 8-Spoke Oversize Wheel
Pro-Line 40 Series Crime Fighter Tires
Electronics
Futuba 3PM FM w/ Receiver
Hitec HSC 5998 Servo
Dynamite 1/2 Aluminum Servo Arm Blue DYN2560
HPI Cap Head Screw for Servo
ID:	2604   Click image for larger version
ID:	2605   Click image for larger version
