32P slipper, what's a good one?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
32P slipper, what's a good one? - 03.31.2007, 10:56 PM
I'm fed up with this POS slipper 'thing' that is on the maxx tranny. It's so useless it's almost sad really, and the spur seems to wobble so much from it makes me want to cry.
So, what I need to know, what is a good slipper assembly that works with 32P spurs, preferably one from Mike. I've looked at them, but it doesn't really say which truck/mounting it's meant for. Thanks a bunch.
squeeforever
squeeforever's Avatar
03.31.2007, 11:06 PM
The only options you have are: stock, RRP (not much better than stock, worse than stock if you want any slip), or the Kippster, which is like the Strobe, but uses RRP spurs. Let me know if you want a Kippster, I have one I can let go of (there VERY hard to find).
rchippie
rchippie's Avatar
03.31.2007, 11:18 PM
Can i get a kippster slipper ? :005: .
REAL MEN RUN BRUSHLESS
squeeforever
03.31.2007, 11:19 PM
Sure, why not. :p
zeropointbug
Z-Pinch racer
03.31.2007, 11:21 PM
Really? What spur do you have with it? the 66T or the 72T?
Do they have little wobble in the spur then?
I'm going to be running it with a 7XL geared for about 45 mph.
squeeforever
03.31.2007, 11:37 PM
No, they don't really wobble. If you get the MGT spring, in combination with the slipper, there should be no problem what so ever. It would be your choice of 66T, 68T, or 72T since I have 2 of one and 1 of the other. I think 2 small's and 1 big one.
MetalMan
MetalMan's Avatar
04.01.2007, 12:16 AM
Also check out BP-Revo's thread. He may have what you need.
crazyjr
crazyjr's Avatar
04.01.2007, 12:20 AM
If you don't go Kipster, none will handle more than the HV novak
squeeforever
04.01.2007, 12:51 AM
Thats not exactly 32P. :P
zeropointbug
Z-Pinch racer
04.01.2007, 01:09 AM
well, it's just that i bought 4 pnion gears from Mike already, and they aren't cheap... maybe i'll think about whether i want to go Mod1, as there are more options for that. Which one is the best slipper (Mod1) then?
Zero
zeropointbug
Z-Pinch racer
04.01.2007, 01:23 AM
Would the best bet be a strobe slipper? Does the Revo slipper work with the maxx input shaft? EDIT: nvm, doesn't work...
squeeforever
04.01.2007, 01:46 AM
Best mod1 slipper is the Strobe, but if you already have the 5mm 32P pinions, the Kippster is your best option aside from buying new pinions. Like I said, the Kippster is almost identical. The pads are even the same material.
MetalMan
MetalMan's Avatar
04.01.2007, 02:16 AM
It is :). Jato spurs fit the Revo slipper clutch, which are pretty much 32p.
zeropointbug
Z-Pinch racer
04.01.2007, 02:20 AM
okay, okay, so what are you offering the Kippster slipper for then? I think i'll just go that route then, if you think they are the same as Strobes.
Thanks Squee
SilentMonster
SilentMonster's Avatar
04.03.2007, 02:58 PM
Just a side note. I hate the stock slipper too but I have managed to eliminate the wobble all together. The problem is the stock spring. I used 2 revo Belleville washers and then another flat washer that is the size of the hex. Of course you still need to tighten it right down or you'll get liquid plastic but the wobble is gone.
Stephen.
"MAKE EM CRY"
