almost doen CRT.5
andywpj
almost doen CRT.5 - 04.01.2007, 12:23 PM
i am almost done it, just test ran so great.
just need battery hold.
Mike.L
Mike.L's Avatar
04.01.2007, 12:38 PM
Nice! your using the steel spur?
  Send a message via MSN to Mike.L
andywpj
04.01.2007, 02:20 PM
yes, i am use stock supr and my super hard motor gear.
look close.
Serum
Serum's Avatar
04.01.2007, 02:33 PM
Where do you get the gears from?
rchippie
rchippie's Avatar
04.01.2007, 03:04 PM
That looks great :017: .
REAL MEN RUN BRUSHLESS
04.01.2007, 05:24 PM
And still messing around trying to get the plastic gears to work. If your spur/pinion lasts a long time, I might just get a hardened steel pinion - although finding a Mod1 1/8" bore pinion seems a bit of a challenge. Not even the dreaded FD carries them.
Nice job!
andywpj
04.01.2007, 08:17 PM
pinion gear is our made some,we made a gear is easy in TAIWAN.
only one consideration is steel material must be over spur.
like i said, we have a lot people made 1/8 CRT truggy conv to BL.
setup like same, all of run stock spur and this pinion gear over 5 or 7 month
pinion gear good and fine not eat anything.
sorry my poor english,
Thank you..
hi BrianG, what is FD ?
04.01.2007, 08:34 PM
FD=Fine Design.
jnev
jnev's Avatar
04.01.2007, 10:51 PM
Very nice job!! They seem to be the perfect size to mess around with... not quite as big as 1/10, but not so small as 1/18 so that they always flip.
Crt .5
rhinopole
Crt .5 - 04.02.2007, 11:49 AM
Andy, were can I buy one of those pinions?
