Hotbodies diffs -
04.03.2007, 10:08 AM
Hey guys,
I have a Muggy and a Turmoil that I converted. They pretty much have the same drive train and I've been running the Kyosho plastic spurs. The thing is that I have to modify the spurs to work with my diffs. I've been doing some reading and there are a lot of references to using the hotbodies diff for the LSP. Does this work with the Kyosho spurs without modifications? Will it fit my applications?
Thanks.
RC-Monster jumper
04.03.2007, 10:19 AM
need shims i believe.
take entire kyosho diff.:D
TEAM FUSION
04.03.2007, 10:23 AM
Hotbodies cars are Kyosho clones... you can swap many parts between the cars. They didn't do much to hide the fact they just cloned a K car.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.03.2007, 11:42 AM
the kyosho spur fit perfect on my slipperentialwith hot bodies diff
04.03.2007, 11:54 AM
yes, kyosho spur is a perfect match to the hot bodies diffs.
04.03.2007, 12:15 PM
does anyone have the part number for the Kyosho 44T spur?
04.03.2007, 12:19 PM
http://www.rc-monster.com/proddetail.php?prod=KYOIF147
TEAM FUSION
I think the #'s are IF147 and IF148 for the 44 and 46 gears, respecitvely.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.03.2007, 12:20 PM
He can get both from Mike......go to search and type in Kyosho spur gear and it will bring you right to it....
04.03.2007, 12:45 PM
I should have been more specific with my question. I'm going to be putting these into Muggy and Turmoil, which use the exact same diff setup. Will this hotbodies diff be a drop in replacement for my existing diffs, or will I have to do something to make it all work? I'm asking because if there are modifications involved, I might just stick to what I'm doing now.
RC-Monster jumper
04.03.2007, 03:21 PM
for diffs it seems that who ever makes the muggy and sportwerks cars they also copied kyosho. they are the same size.
04.03.2007, 06:57 PM
jolly, I'm surprised that you didn't know (or maybe you did). The Muggy is a Losi truck and Sportwerks is a Losi owned subsidiary.
Thanks for the heads up on the diffs, I'm ordering them now.
RC-Monster jumper
04.04.2007, 04:24 AM
i'm not here to argue but a muggy is made FOR losi, not BY losi.
04.04.2007, 12:14 PM
jolly, I wasn't aware of that. Is that true of the LST also? I'm just wondering. I actually had the opportunity to get an 8ight T, but decided on the Muggy because I'm only a light racer and mostly bash. I have five vehicles and my spare parts box is getting rediculously big. The Muggy is easy to stock parts for, because duplicate parts are used throughout. It's a tough truck too.
Oh, BTW, do you know who does make the Muggy? They used a lot of parts from the LST(2) to do so and a bunch of parts are also interchangeable between the Muggy and my Turmoil.
RC-Monster jumper
04.04.2007, 04:05 PM
i dont know who makes it.
but i do know its not losi.
aftershock, lst, lst2 and muggy aswell as some sportwerks cars are made by an outside company. they share lotsa parts.
but anyway its a nice truck, that muggy.
