Anyone run a 2230?
pb4ugo
Anyone run a 2230? - 04.16.2007, 11:55 AM
Looking for feedback on the 2230. Especially compared to a 1950. Will the larger diameter produce that much more power?
Enough to overcome the shorter length?
BTW, I tried the search, but ended up with alot of 2240 info.
Dafni
Dafni's Avatar
04.16.2007, 12:20 PM
I never had a 2230 myself, but not too long ago I saw a CEN MT with a 2230.
I felt with the same voltage I'd still take my 1950. It was very nice and powerfull, but nothing that made me go WOW. I stick to my 1950s.
Serum
Serum's Avatar
04.16.2007, 12:59 PM
the CEN as published on rc-independent daf?
i guess so?
Don't expect too big of a difference between a 1950 and a 2230.
don't know if you knew; the 1950 has got a 19mm diameter rotor, which is 50mm long and the 2230 uses a 22mm diameter rotor which is 30mm long.
i doubt if you would notice a difference between a 1940 and a 1950 to be honest. Both are capable of more than enough torque, and both are capable of producing the same power (battery limitations)
Dafni
Dafni's Avatar
04.16.2007, 01:18 PM
No, it was not the one in the mag. Not the nice one, unfortunately not.
Alex from BK has a Genesis too. He kept going on about it like it was the best thing ever.
Serum
Serum's Avatar
04.16.2007, 01:20 PM
Too bad.. LOL
if you see the shafts, they should be able to run a 1:1 car... Looks.. that's what it is.. Too big.. Too heavy.. everthing is just 'too' on that thing IMO..
pb4ugo
04.16.2007, 06:20 PM
i guess so?
That's what I was hoping for. I love my 1950, but a project I'm working on would benefit from the shorter length of the 2230.
I'm also worried the 1940 would struggle with 14-15 lbs of truck to haul.
