calculator help. -
05.15.2007, 04:57 PM
since brian g just helped me, nvr mind
hey i was tryin to learn that, i really need to so i dont have to ask, but
i want 45 ish give or take a lil bit.... when i type in what i THINK for the crt .5 or everything i get 46mph, but then i type my info into the motor chooser and it says its to kigh of kv, which may be over heating, but it worked fine with u go to speed, so idk, can u tell me what i need for this?
5700 kv, idk on what pinion, the tock spur i for now anyways unless mike comes out with the plastic stuff, 6 cells, stock tires for now, but always the same size
so what can u do to make the motor run under 150F after like 20-25 mins of runtime AT THE MOST? while around that speed?
thx guys:018:
