I have a hacker b50 10xl and a mm in the mail and I want to run 12-14 cells and I was wondering if anyone had a basic idea for gearing for it. it weighs about a 1/2-3/4 lb over stock. I want to have an Idea to be close and so I can go from there. I just don't want to blow up my mm right away. also the battery (6 or 7 cell packs) must be wired in parallel right? thanks
Use the speed calculator in briang's signiture. Subtitute the b50 10xl for a wanderer 10xl they are very close to each other. That should get you pretty close.
You could easily run 14 cells, and probably want to, not 12 cells.
What kind of speed are you thinking? IMO, I would gear it 22/51, for up to 40mph top speed.
If a hacker 10XL has a KV close to a BL 10XL, I'd got with more like 16 cells or 5s lipo. That way you won't have to gear up as much. On 12 cells or 4s lipo, I'd say a 7xl or 8xl.
I agree, I would rather run a couple extra cells than gearing it up. Do you know what the limit for ratio is for the 10XL Brian?
But I would also just as likely run a higher Kv motor like 8 or 9XL on 14 cells.
I thought NiMh could not handle a 7XL? and barely a 8XL...
There isn't a gearing limit per se. It comes down to weight, drivetrain/rolling resistances, and battery power.
I was using the 10XL on 14 cells geared 14/40 on my ~10lb Revo with stock tranny locked into wide-ratio second gear. Motor temps were a little warm, but not too bad. I had sized the motor for 5s lipo but never got around to getting them since I had three 14-cell packs already. 5s would have let me run better gearing (probably run std or narrow ratio gearset in the tranny) while maintaining decent track speed (~35mph) and cooler motor.
And that is true; NiMH cells may have a hard time keeping up with the 7XL effectively, but again depends on weight. If it takes X power to move Y lbs, it only stands to reason it would take less power to run less weight. Still, NiMH works, the voltage just dips more than a properly sized lipo pack.
I would like to be running mid-low 30's in 2nd and I want a system that wont put to much pressure on the mm. i have various spurs between 51-70 but only one pinion which is a 17. which would most likely run the system cool? I am a basher and I am shooting for more torq a little more speed and quite a bit more run time than stock.
That speed should be fairly easy to get since the stock Titans aren't too far away from that. I would find the ideal gearing using the "solver" calculator. Then, you can go up or down from there depending on motor temps.
