540c xl rear endbell clamp.
Mightytaco
540c xl rear endbell clamp. - 05.24.2007, 09:58 PM
Are you guys having issues with the endbell coming off of the 540c version of the Fiago motors? The mount i made for my conversion has support for it, but ill be upgrading to Mike's mount since it will make the buggy a whole lot cleaner looking. I did see the nice heatsink / clamps offered in the store, but didnt see one for the 540c.
Also, the Jammin CR mount does fit all OFNA buggies correct?
AAngel
05.24.2007, 10:50 PM
The motor clamp/heatsinks are for the smooth can motors. I don't own any "C" motors and the problem you are having is the reason why. I understand that many have used JB Weld to hold the endbells on.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.25.2007, 08:37 AM
Taco, I have the same problem with my 2 540C 7XL motors... I just sold them, and keep the smooth can..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Mightytaco
05.25.2007, 04:24 PM
Hmmmm.. Ill have to get creative then. I haven't had the problem yet, but as i said, my current mount supports the endbell. It just looks horrible.. :) If i knew then what i know now, i would have went for the smooth can. Thanks for the replys guys.
Serum
Serum's Avatar
05.26.2007, 02:35 AM
You are talking about the endbell; but do you mean the back or the front of the motor (front as the side where the shaft sticks out)
mine has got an M3 screw in the end-bell that sits on the back of the motor.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.26.2007, 03:54 AM
Yeah, I had a frightening moment where the set screw (like Serum said) went too far in and got lodged in-between the end-bell and the motor coils. I had to swallow hard and give it a turn and HOPE that it would not damage the coil at first, luckily it didn't, but I put some thread lock on it. I'm not really using it, I just thread the end-bell on until it's good and tight. Hasn't come loose yet.
Mightytaco
05.26.2007, 08:49 AM
Yeah, i was talking about the rear of the motor. I unscrewed it once to check it out, but wasnt sure how good that set screw kept it in place after repeted bashing.
Serum
Serum's Avatar
05.26.2007, 08:59 AM
That's not an issue IMO;
Turn it 1/4th turn loose, ad loctite to the M3 screw and tighten it onto the aluminum can.
