MGM Programming Question
Sower
Sower's Avatar
MGM Programming Question - 09.22.2007, 03:51 PM
Hey guys - I have a question about programming my MGM. Big surprise, eh? Well, I got the 160 from Mike this last week and have done a preliminary transmitter programming thanks to Jhautz and a few others posts. The problem is that I pait $30 for that USB connector and it's not doing a dang thing! Do I NEED to have that other $10 patch cord that is out of stock right now or can I do it w/o it? I would really like to customize everything and make sure I did the settings correct. Any help is great - thanks.
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.22.2007, 03:54 PM
I used both to do it. I am not sure if there is another way. Maybe someone else.....?
Sower
Sower's Avatar
09.22.2007, 03:56 PM
Well, there are diagrams that show you how to do it without but none of them actually work.
wallot
wallot's Avatar
09.22.2007, 04:10 PM
do you have battery connected to the ESC while using USB? you have to have it connected
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
 Send a message via ICQ to wallot
Sower
Sower's Avatar
09.22.2007, 04:12 PM
Yep, there's power to the ESC. We've even tried doing a "Y" cable scenario in the .pdf and nothing seems to work.
lxmuff
lxmuff's Avatar
09.23.2007, 06:18 PM
I don't know if you understood what he meant. You need the main battery connected to the esc, unlike the MM. It doesn't seem right but it does work either way with the esc to rx cable or the seperate C02 cable.
Sower
Sower's Avatar
09.23.2007, 10:18 PM
Yeah, I've had the main battery hooked up to the ESC. I don't run a reciever pack, but I tried that way too. Basically it looks like I have to get the other $10 cable. Everything else seems to fail.
