How much steering torque for a GMAXX w 3.3 suspension?
discusdave
How much steering torque for a GMAXX w 3.3 suspension? - 10.10.2007, 11:53 PM
Hi Guys,
I am going to start a GMaxx G3 and G3.3 BL setup with a Novak HV Maxx 6.5. This will have a SuperMaxx Gen 4 steering setup, and I wanted to know how much torque to have in the Steering Servo? I have a Hitec Digital HS-5945MG with 181 oz/in at 6v, which is what it would get from the Novak ESC. Is this enough, given the chassis I mentioned? Thanks for your help.
Dave
Serum
Serum's Avatar
10.11.2007, 01:54 AM
anything above 10-11 kg/cm would do. unless you are using huge tires. I like mine fast. You could add an external UBEC to get the full 6V, but i thought the novak deliverd 6V as it is?
discusdave
10.11.2007, 02:28 AM
Thank you for your help Serum. Thanks to handy online torque conversion tables, 181 oz/in of torque = 13 kg/cm, so I guess I am OK with the Hitec I mentioned. And yes, the Novak ESC in the BL system delivers 6 volts to the steering servo.
My other thought was to go to a dual servo setup, but no reason to add to the weight of the rig if one servo will do the trick.
Dave
mwry13
mwry13's Avatar
10.25.2007, 12:57 PM
i think the hitech 5945 is the minimum for that car, to be safe ide use something like an airtronics 361 or so.
200 Oz at 6 V
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
