Hi, I'm new here. I'm building an all out race Maxx and its almost done. Of course, it will be brushless, powered by a Feigao 10L and BK 9920. This project has been going on for well over 2 years because of all the new ideas and design changes. The point of this project is to have an extremly light ,fast and agile beast. Because of that goal 80% of the parts on this truck are one-off's, all made and designed by me.
Heres a list of parts
6061 Aluminum chassis (currently being lightened)
Machined aluminum center tranny riding between nylon blocks
Delrin rear lower arms
Turnbuckle upper arms
RPM molded hubs all the way around
Polished stock pillow balls and hingepins
Modded RPM front arms
Garolite upper deck/brace system (In the works)
Garolite front shock tower
7075 Aluminum rear tower
Integy non piggyback shocks
Kyosho springs up front, Trinity in the rear
Shortened Revo center sliders
Modded Maxx sliders at all four corners
Stock diffs, ring gears were hardened and tempered
Lightened Integy rear bulks
Pro-line velocity wheels
Traxxas Sporttraxx rubber and foam
Pro-line GMC Sierra body
Hitec 645MG
This is an old picture, but the rear was unchanged
It may look heavy, but it weighs in at 8lbs fully loaded with 14 cells and a spare motor. It should be closer to 7 with all the weight I'm taking out of the chassis.
