Diff rebuild question.
mkrusedc
NeuMaxx
mkrusedc's Avatar
Diff rebuild question. - 11.10.2007, 02:02 AM
I am putting my FLM hybrid bulks and HB diff together. I don't want to put it together backwards.
When looking at a OE E-Maxx diff housing there is a thin conical shaped 1/2 and a thicker square 1/2. Am I correct that the ring gear is on the thin side and the cup is on the thicker side?
GorillaMaxx360
GorillaMaxx360's Avatar
11.10.2007, 10:36 AM
with bushels it does not matter which way the diffs are arranged. as long as the front diff is opposite as the rear diff it if goes in reverse just switch the motor wire. I can not remember how the diff fits in the housing. if i can remember right i think it fits on both sides fine but i think you might be right, but i am not sure. try the diff on both sides with the pinion mesh and see what one works better, if they work the same it probably does not matter(maybe it does). sorry cant really remember how my diffs are in the hybrids
Serum
Serum's Avatar
11.10.2007, 10:45 AM
What exactly are bushels?
can't put my finger on it.
Have you got helical cut gears? they have got a favourite way of turning.
GorillaMaxx360
11.10.2007, 10:50 AM
sorry serum i ment brushless typo
Serum
Serum's Avatar
11.10.2007, 10:52 AM
holy cow, i spent the entire day searching for bushels..
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.10.2007, 11:51 AM
Duh!!! Thanks you are right it doesn't matter.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
11.10.2007, 02:19 PM
i thought it was a new diff technology i wasn't privy to.
i have bushels of laundry to do.........
Eflite Blade 400 heli on 3s
Serum
Serum's Avatar
11.10.2007, 02:23 PM
No worry mate, i've got plenty of bushels upstairs! (not kidding either)
ClodMaxx
ClodMaxx's Avatar
11.10.2007, 02:27 PM
can i send mine across the pond to be put in yours to get done? i hate laundry.
i think i have sore bushels, too. the non-laundry kind.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.10.2007, 08:35 PM
I have the HBC8030 13T bevel gear. Will that be an 8mm shim?
