Max Current of Neu 1515 1y
mabu
Max Current of Neu 1515 1y - 11.28.2007, 12:11 PM
Hi,
how much current is the maximum Neu 1515 1y "wants"?
I have 3 possible controllers - 150A, 120A and 100A Maximum current ;)
mabu
11.28.2007, 01:45 PM
According to this source 180Amps ...
What Controller should be used so?
Serum
Serum's Avatar
11.28.2007, 02:01 PM
these 100,120 and 150 numbers make me think you want to use a BK controller?
It would depend how many volts you put it on and how heavy your vehicle is.
mabu
11.28.2007, 02:03 PM
Oh Sorry ... only the 150 Amp Controller is a BK Warrior 15020.
I want to run it within a Revo on a 4s Lipo.
Serum
Serum's Avatar
11.28.2007, 02:16 PM
the warriors won't run a neu motor.
On 4S 100-125A should be plenty, what cells are you going to use?
mabu
11.28.2007, 02:20 PM
Oh ok ... what controller should i use now? a Mamba Max?
I wanted to use Kokam H5 Cells.
Chapito
11.28.2007, 03:04 PM
You realy need a controller designed to run at least 4s. The Mamba is only speced for 3s. The best two choices available currently are the Quark Monster 125b and the higher rated MGM controllers. Both have pro's and con's. The Quark requires at least a heatsink to run cool enough in warmer climates but is fairly reliable until or unless it has thermal bonding separation issues. I don't have an MGM but they get generally good reviews and feedback on this forum and are probably the best overall choice. Hopefully the Mamba Monster Max and Tekin 1/8th scale controllers will soon be available but until then the previous mentioned controlers would be your best bet.
mabu
11.29.2007, 06:11 AM
Ok, i am gonna use the Quark Monster... I hope Mike ships it asap
The last two parts to get running my erevo
Connectors ?
mabu
Connectors ? - 11.30.2007, 01:51 PM
And which connectors should i use? a suggestion was Deans - but i thought these were only useable til 50A
neweuser
neweuser's Avatar
11.30.2007, 01:58 PM
Deans will be just fine. :)
mabu
11.30.2007, 02:04 PM
Fine thanks - i do not want to melt this system or blow it up ( like a friend did in a local forum )
neweuser
neweuser's Avatar
11.30.2007, 02:08 PM
Deans are real common. I run mine on 5s as well, never melted one yet. Not even when my old Nimh's blew.
mabu
11.30.2007, 02:25 PM
is there also a common standard how to connect them?
Duster_360
11.30.2007, 02:33 PM
The fem deans goes on the batt - too easy to short the other way. If you're asking how to connect the wires - see the package, on rear is a diagram showing which is positive/negative and which side of terminal wire should be soldered to.
mabu
11.30.2007, 02:54 PM
well i only got 2 pairs attached to my last buying ... i hope to get some at ebay soon
thanks so far
