Motor Life?
Shark413
Shark413's Avatar
Motor Life? - 12.17.2007, 05:37 PM
Just wonndering, do brushless motors lose there magnetism over time? I know if you over heat them, they will lose their magnetism. But what about motors that are kept within specs, do they still lose their magnetism, just at a slower rate and over a longer period? And if they do lose magnetism how long do motors normally last? Is there a difference between highend (Neu) and bargin motors (Feigao) regarding how long they will produce acceptable power?
12.17.2007, 07:20 PM
I'm sure they do eventually lose some, but not sure how much. There are many brushless motors out there in your everyday appliances (washers, A/C units, etc), not to mention industrial applications, and it's not uncommon to have those running much more frequently for years. Of course, those motors aren't subjected to the intense sudden loads R/C BL is, but still. I would think that as long as the bearings are replaced and the motor isn't overheated, you should be able to get several years of life.
BTW: Not only heat makes magnets lose their power, but vibration as well...
