10s1p A123 Truggy video with eagletree data inserts
othello
HV basher
10s1p A123 Truggy video with eagletree data inserts - 01.02.2008, 02:29 PM
I finally managed to shoot a video of my truggy (Robitronic Mantis) running on a snowy surface. I synched the video footage with a playback of my eagletree logfile.
Clip1 (Windows Media, 640x480pix, 4m42s, 52Mb)
Clip2 (Windows Media, 640x480pix, 2m53s, 32Mb)
Eagletree graph of this run
I made some graphs with Excel based on the data of the eagletree logfile showing the Watt, Amp and RPM distribution during this run.
I use the following electric components:
. ESC: Jazz 55/10/32 (55A cont, 65A peak)
. motor: Neu 1512/2Y (1400 kv)
. Batteries: 10s A123 (33V)
More details and some pics of the setup can be found in this thread. I now run it without fans.
Beside those crazy ballooning front tires (center diff is filled with 30000 oil) and the not so perfect damping of the rear axle i really am very happy with the actual setup and performance.
Enjoy
lutach
lutach's Avatar
01.02.2008, 06:15 PM
That is awesome. I will have to make a video now of my BPP truck . I admit, I'm a little jealous .
pb4ugo
Awesome! I really like the performance!
Is 7 minutes your normal runtime?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
01.02.2008, 06:33 PM
I like dude.. awesome job...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Aragon
01.02.2008, 06:43 PM
Very cool!
othello
HV basher
01.02.2008, 08:17 PM
Glad you guys like it as much as i do
@pb4ugo
Normally i run 9-13 minutes per charge. On this run i pushed the truggy as hard as i could and was really surprised that i used more than 20A average (which corresponds to 570 Watt average). On my preceding 60 runs my average current draw hovered between 10-15A. It really depends on how much grip you have and how hard you run it.
This for example is a more typical graph of my runs. If you compare the Watt, Amp and RPM distribution of this run (nr. 38) with the above linked graph, you will see that on my video run almost 50% of the runtime the motor RPM was between 25000-45000rpm and on run 38 i drove the motor only at 25% in the same rpm range. More full speed driving costs more energy, which reduces runtime (nothing new there ).
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.02.2008, 08:43 PM
Cool vids man. Love the power that it puts out.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
othello
HV basher
01.02.2008, 09:25 PM
For 1/10 of a second the highest power peak on this run was at 2,5KW. In my lighter buggy i saw power peaks up to 1.8KW with the same components and a similar top speed gearing.
The Neu 1512 is rated for 2,5KW for a short period. Guess i reached it's rated maximum. Those A123 cells do deliver about 100A max for short bursts and are only warm after a run since i only draw 10-20A average.
satttheman
satttheman's Avatar
01.12.2008, 09:24 PM
got voltage???
dang bro thats a sick truck and a lot of volts i thought i was nuttz running a 8ight-t on 6s lipo
Projects:
FLM Savage
othello
HV basher
01.12.2008, 10:08 PM
Judging from your signature you are kind of a powerfreak too
The main purpose when i switched from a 12 cell Nimh setup to a 10s A123 setup was to lower overall temperatures of my electric components by reducing Amp draw. A nice byproduct was more performance.
2 months ago i moved all components in my truggy. Take a look at the videos in my signature to see the same setup performing in my truggy.
satttheman
satttheman's Avatar
01.12.2008, 10:32 PM
thats a very sweet setup i might try that to lower my temps
Projects:
FLM Savage
rschoi_75
Certified Spaceball
rschoi_75's Avatar
01.12.2008, 10:35 PM
great video.
rcm xt8
rcm xb8
rcm crt.5
othello
HV basher
01.12.2008, 10:51 PM
guess i got confused with the title of my own thread as i posted another video of my buggy which was also powered by the same setup.
Those videos can be found here.
