The picture on the site is actually a stadium truck version of the komodo. There is only one maxx sized komodo tire, and this is what I carry. Sorry if the picture mislead you(didn't have a maxx komodo picture handy). You can see the maxx komodo tires mounted on my extended pede in this thread: http://www.rc-monster.com/forum/show...p?threadid=122
Okay, so i am not the only one who thought the tires where too hard when you use the entire foam.. I think i will go to a shop here, he has got the ability to cut foam really good.. (he makes custom carseats
I was looking into getting a set for my Race Maxx. I use BowTies on RPM Stablemaxx's now with stock Tittans/EVX for now. How much do people usually gear up?
I'm getting a set of UE diffs in this weeks, and I just ordered a pair 22T pinions along with a FLM rear bulk from Mike. If I'm geared 22/66 with Bowties and UE diffs, what should I gear with the Komodo's??
I could have supplied the UE diffs as well, nitrostarter! I guess if you are geared that high already, you have to go to the 54 tooth spur gear to get any taller.
What else can you get and why this inst on the website? Man, I didnt know you could get them. I would have gave you the money rather than the guy I got them through. But one reason I went my route is because I've heard horror stories of putting them together. I get aggrivated easily when things arent WAM BAM and lets go. The diffs I bought were used for about .5 gal.
Anyways, I was looking into getting the Strobe slipper setup if I have to gear lower with the Komodo's. Thing is, $12 per pinion vs. $3.50 per pinion when I'm only going to need one of them when I go BL.
What pinion should I run with the 54T spur and Komodo's? And do you have that spur?
