hemiblas
hemiblas's Avatar
03.05.2009, 09:54 AM
I'm with the Linc on this one. Seems like the only good use for these feigaos are for boats. You have 70 degree water cooling the can and they can run forever. Or if you are like me you add a bunch of fans and a heatsink to keep it cool on a truck. The KB motors have the same issues even when you go 6S and low KV and they are bigger than this thing. Pretty much its any inefficient motor without any type of cooling just isnt going to work for the long haul in a truck unless you are going to do some major mods to keep it cool.
Its funny because I've read over the on the boating forums, when the boats stop the feigaos start to heat up cause of all the heat inside that transfers to the outside can without the cool water flowing over it. A lot of people make that point that you need to check the inside temps and that it can destroy these things, but the fans and/or water keep the can temps from going thermal overboard and the motors from overheating. I think Neil says it best "Spinnig toast of death".
