Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
dangerwr
12.14.2008, 11:21 PM
Originally Posted by ssspconcepts View Post
The stock diffs were plenty robust...I had a spare set of the spiders. I figured I'd use the spiders since I had them handy and they are smoother than the stockers. Not exactly sure, but the car is probably 10-15% lighter than the Jammin buggy-IMO. It is considerably lighter than my BL Jammin CRT, which is set up with the same conversion stuff.
Are these the Spiders you are using?
http://www.amainhobbies.com/product_...ducts_id/24323
http://www.amainhobbies.com/product_...ducts_id/24324
Not exactly cheap! I think I can find them on eBay for a bit less. Not sure but will probably run the stock ones in the F/R but replace the center diff with a Spider. You mentioned there was a fit issue or is it a direct fit?
ssspconcepts
ssspconcepts's Avatar
12.14.2008, 11:56 PM
Those are the ones. If you drop in a center diff, you will have to replace your rear center drive shaft with a different size...I have a spare if you need it.
dangerwr
12.15.2008, 12:19 AM
Thanks! I will let you know once I actually get down to it. I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
ssspconcepts
12.15.2008, 02:38 AM
I don't know yet...
My preference is to use either center diffs or trannies with a slipper. Mike's slipperential...when it is released...will do both!
To answer your question...you can simply install the collar that comes with that center solid shaft on the DM-1 stock 2-speed. It should work fine....when you get to that point there are plenty of members here that can help.
ssspconcepts
12.15.2008, 11:38 PM
Latest progress:
From DM-1 Spec
From DM-1 Spec
12.16.2008, 01:13 AM
...I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
I personally like the solid shaft. A center diff unloads too much and spins the front tires unnecessarily and you lose power. Unless you put really thick oil, and then where is the benefit? Maybe on a track where cornering is vital, but these have so much power that it's easy to drift around the corner if you want to turn tight.
I don't know what benefit a torsen diff (if that's what you mean by "spider") would offer. I can see using it in the front or rear to keep one side from unloading on corners. But the combination of stiff suspension and sway bars helps that a lot. Otherwise, it kinda acts like a solid shaft if used in the center...
rchippie
rchippie's Avatar
12.16.2008, 01:19 AM
That looks great . I almost got that car instead of my gtp . Does the battery hang of the chassis much ?.
REAL MEN RUN BRUSHLESS
ssspconcepts
12.16.2008, 02:18 AM
It is a really nice kit car...I am continually impressed with the quality of the Ofna products that are available. I guess about 1/3 of the battery hangs off the chassis. The is probably too much for your comfort as I recall from your previous posts a long time ago...but the tray is delrin, and this is a street racer, and everything is bolted down nice and tight...
rchippie
rchippie's Avatar
12.16.2008, 02:29 AM
your probably right . Since it's a onroad car as long as your tray is securly mounted it should be all right .
ssspconcepts
12.16.2008, 02:24 AM
I used 90wt diff fluid (which was the thickest that I had on hand). I am going to try the diff and then try the center spool. I just wish somebody made a heavy duty center slipper to go with that solid shaft....
12.16.2008, 10:50 AM
....I just wish somebody made a heavy duty center slipper to go with that solid shaft....
Yeah, that would be nice. But believe me, the tires slip enough. Seriously, I don't think the lack of a slipper is a big deal. Other than controlling take-offs, the other use of a slipper I can think of is to absorb drivetrain shocks when landing from jumps. Do you plan to jump this?
ssspconcepts
12.16.2008, 02:42 PM
Those are good points...no jumps planned for this car. I am going to give it a few runs as is. If it diffs out too much and eats the front tires I will definitely swap for the solid center spool. I just did not want to keep the 2-speed because I NEED reverse and I used all of these parts (center diff) because I had them on-hand.
speedracer1129
12.16.2008, 11:32 PM
Are you sure you used the right oil??? That there is shock oil, no good for diffs!!
Nuclear
California, Redwood
12.17.2008, 01:25 PM
Hello, winter project. just wanted to know, can you list the price of all your parts you used, including price of the car....esc...motor....etc....
thank you.
ssspconcepts
12.17.2008, 11:02 PM
I could be wrong but silicone fluid is silicone fluid...the stuff I used was 9000cst viscosity not 90wt. Its pretty darn thick and seems to work fine in some of my other trucks.
