Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Robl45
12.27.2012, 11:47 PM
so are there any reasonable priced low kv motors you could recommend? otherwise i might end up going 4-5S when this motor burns out.
An airplane esc generally isn't as smooth as a car esc. The Hobbywing will be more controllable as it is programmed for car use. The reason you see more higher Kv motors out now is because the most popular conversions are buggies and truggies. Most of them are limited to 4s use in the classes they race in and 4s is cheaper for bashers too so higher Kv sells better. All else being equal (including top speed) a lower Kv with higher voltage will be more efficient than higher Kv and lower voltage. Motors like the 11xl needed to be lower Kv with higher voltage to pull around larger trucks like the LST.
The Losi mount has a 43mm diameter so it will take a Castle, Tekin or most any finned motor. But those fins don't contact the mount causing it to hold heat in, plus it's limited in its gearing. If you kept the Kv around 1500 you could run 6s (stock trans gearing) with the Losi mount, but 2200kv you would need to drop down to 4s to keep the speeds and temps in check. I wouldn't recommend the 11xl or similar 36mm motor in the Losi mount.
Mozzy
Mozzy's Avatar
12.28.2012, 01:19 AM
Look for a Leopard 4082 1600kv & you can run 6S. They are sold from Hong Kong on ebay. Free postage too!
The larger the diameter & longer the can the more torque it will produce over a smaller size can with the same kv. So. don't just think a lower kv will improve things without taking into account the can diameter & length.
It is smooth canned & will fit a Losi mount.
I use this in my 1075mm Cat boat running twin 6S in parallel. It goes ok.
http://www.youtube.com/watch?v=eJO5N0Wh4eU
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
CerberusVI
CerberusVI's Avatar
12.28.2012, 04:33 AM
I like how you put that "it goes OK" 1:30 into the video and its screaming across the water! I've been looking into the leopard 4082 1600kv for my conversion. I have a castle 1520 but don't want to keep taking the motor out of my truggy to use it. I've heard good things about it so far
Robl45
12.28.2012, 10:25 AM
That motor doesn't look bad at all especially for the price. Would anyone here recommend sensored over sensorless or does it not really matter anymore?
Mozzy
Mozzy's Avatar
12.28.2012, 12:24 PM
Sensored is more suitable for racing applications where you want a very precise feel at low RPM. Like exiting a slippery corner.
Sensorless is better for high power requirements. I use the Mamba Monster with the 'Torque Control' setting active & no 'Punch Control'. It seems to be much smoother to drive. This ESC has given me hours of 'driving pleasure' with no fuss at all. I update the software regularly & it never misses a beat. MM's are not too badly priced from ebay either.
If you want a motor that they don't currently have in stock, just email them & they should be able to give you an indication of a restocking date.
I bought mine from ebay, along with the water cooling jacket.
BTW, I don't think the boat is quick yet. I'm upgrading my ESC to a 240HV & running it on 8S.
Robl45
12.28.2012, 01:49 PM
what makes sensorless better for high power applications? Finally got the truck out again today with my son and his mini summit. Complete disaster, it has so much power it just flips over constantly. I had an aluminum wheelie bar that sheered all four bolts holding it on. Looks like I"m looking for a new one unless I can figure something out.
I also think I damaged the transmission as its making a funny sound now. Still driving fine but definately making a different noise than it was.
any ideas how to calm this thing down? One speed conversion probably calm it down I assume, not really sure how the pinions work on this since I guess you have to replace both of them if I wanted to go smaller pinions or something while I have the 2 speed.
As for temps, battery was slightly warm, 6s 3000mah 20-30c pack, ESC was quite warm to hot and motor was pretty hot. Hot enough that you wouldn't want to touch it for more than a quick second. Sorry can't be more precise than that, I used to have a temp gun when it was nitro, but it died and I haven't needed one since.
Mozzy
Mozzy's Avatar
12.30.2012, 03:02 AM
You may not have damaged anything, the motor mesh may have moved. That's happened to me in the past. I have beaten the crap out of my truck & never had the transmission or diffs let go. They are still the stock LST2 stuff.
I don't think your battery is able to cope with the required amp draw. You should increase both the C rating & mAh/capacity of the pack.
Always have batteries that can deliver at least 20% more power than you require.
I use the Turnigy 6S 4000mAh 40C packs & they barely get warm.
As for 'calming things down' adjust the power setting lower in the ESC.
Spoon feeding people is not my idea of education. Do some research, Prof. Google is there for a reason.
Here are a few links which you should read before asking anymore questions. The first one is pretty good & has pics. The rest are just forums.
http://rctruckstop.com/2011/12/15/br...vs-sensorless/
http://www.rcgroups.com/forums/showthread.php?t=975447
http://www.rctech.net/forum/electric...ensorless.html
http://www.ultimaterc.com/forums/sho...d.php?t=140618
http://www.hobbytalk.com/bbs1/showthread.php?t=226007
Robl45
12.30.2012, 11:56 AM
I know you mean well, I've been reading everything I can find on this stuff. I checked the gear mesh, spurs and pinion look fine. mesh seems okay. I'll have to tear it down when I have the chance to check it out more. I think hitting the palm tree at full speed didn't help it :) It was far out and I didn't judge it right and smacked into the tree.
Anyway, The battery at the end of the pack is warm and nothing else so I think its okay.
I can't calm it down with the current ESC, but I think the gearing needs to be changed. otherwise it will wheely all the time with no end in sight.
I used to race all sorts of brushed cars 20 years ago, I'm just not really familiar with this one when it comes to setting up this brushless conversion.
Overdriven
Destroyer of Tires
Overdriven's Avatar
12.30.2012, 05:27 PM
Switching to a single speed is going to calm the wheelies a littleif you keep the same top speed gearing. Right now you're geared for about 44mph btw. But it sounds like your motor is already at its temp limit, I'd seriously consider a new motor.
From what I remember the Fine Design kit placed the battery out back, I'd consider moving it up front to help curb the wheelies also. As far as your weird sound, its likely not the trans, the diffs are more likely to blame. Factory shimmed diffs are tough, but don't always hold up very well to brushless power. Your palm tree incident may have something to with it too. I actually cracked a front diff case in an impact, no other damage was done either.
Robl45
12.30.2012, 05:52 PM
yea, singlespeed I think its going to be first thing I do with it. I don't care for the fine design kit, I just got the parts used so I have them. the battery mount sucks, it uses rubber bands which I have to credit FD did send me some for free last week when one snapped but they are awefully tough to go over 6s battery.
I noticed the back center drive shaft is a little bent. diffs seem good. checked the gear mesh earlier and it looked okay. i'm gonna rip the tranny down to do the forward only once I get new esc anyway.
I'll have to get this kit soon I think, that fine design motor mount isn't the best, screws it comes with would make you laugh, i'm afraid to take them out as I know they will never go back in again without stripping.
Big House
Big House's Avatar
01.02.2013, 06:30 PM
I completely did away with the transmission set up in mine and fabbed up a solid spool with the motor sitting on top. I don't like transmissions...to many moving parts to fail.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
Robl45
02.21.2013, 12:02 AM
This 42 finned motor would fit the motor mount right? I know awhile back some said they should fit, just wanted to check before I bought.
http://www.falconsekido.com/products/xrm4274sd
Mozzy
Mozzy's Avatar
12.30.2012, 06:33 PM
I had a really bad experience with FD years ago & I would never recommend them for anything, because, their designs certainly aren't fine!!
I have my battery mounted exactly where the tank used to be & wheelies can be controlled quite easily by lowering the suspension. Mine is mostly used for speed runs anyway, so, being lower is much better for me.
I agree with overdriven on the possible damage too. Pull your diffs & check them & while you're at it get the TiNi crown & pinion gears for your diffs, they will last longer.
I have heard of people using metal diffcasings too with great results, but, I never bothered & have had no troubles so far......touch wood!
Good luck with it & keep us posted.....give us some pics!!
Robl45
02.27.2013, 11:47 PM
one other question, unless i'm wrong, the front and rear of the truck are the same, my battery box is currently mounted on the rear where the fuel tank would be. Can i mount it up front where the radio box is? Same mounting points, be very easy and just move the radio box? My concern is this would put the battery too far forward and mess up handling or wheelies. I would like it to do some wheelies and stuff.
Overdriven
Destroyer of Tires
Overdriven's Avatar
02.28.2013, 01:10 AM
The Losi mount is 43mm inside diameter. I mounted the Losi conversion tray up front on my truck, but I did not use the stock mounting points of the tray. In my opinion handling benefits from the battery being up front. On power steering is improved tremendously and the truck will still wheely easily even on 4s.
