lutach
lutach's Avatar
11.14.2007, 01:41 AM
Originally Posted by squeeforever View Post
The XL motors should fit no problem. Even with a RC-M heatsink. I'll let you know when I get it machined. Might be a few weeks, but when I do, I"ll get a couple machined.
The Neu finned, Hacker C50 and Align 600L will not fit unless you widen the braces a bit. You will make the motor mount and the bearing support? Are you make the bearing holes lower? I'm asking this because the shafts are hitting the outdrives and it mihgt be adding a bit of drag in the drivetrain. I'll take a picture tomorrow so you can see the damage so far.
